Cruise Control
Old Apr 20, 2010 | 11:02 PM
Lorth's Avatar
Cruise Control
Sometimes the cruise turns on easily, sometimes I have to press the button 20 times, sometimes the thing just wont start after pressing millions of times.
I have no idea where to start, have you guys ever been in this situation, please help.
Is there a way with the TECH2 to look at it while tryin to run it?
Old Apr 21, 2010 | 04:03 AM
Nighthawk243's Avatar
First step is to disconnect the negative battery terminal (in the trunk) for 15 minutes, then reconnect it. For some odd reason, the cruise ends up getting messed up somehow in the computers and doing this resets the computer and often fixes the cruise control issues. When I first got my Cobalt, cruise didn't work and doing the battery trick fixed it.
If that doesn't help, the next possibilities are the wheel switches, the clutch position sensor, and the brake sensor.
Old Apr 21, 2010 | 04:11 AM
sundevil07's Avatar
i just put my foot under the clutch pedal, pulled up and wahla hasn't given me an isssue since
Old Apr 21, 2010 | 12:48 PM
Lorth's Avatar
So everytime the cruise starts messin up, I should remove the negative cable from the battery for 15min and this should fix my problem, will this also reset my clock/radio chanels, etc?
ColonelMustard
North Pacific
Sep 29, 2015 03:02 PM
Extremespeed
Sep 29, 2015 04:34 AM
jrocstar
Sep 26, 2015 11:42 PM
Coballin13
Sep 25, 2015 08:43 AM
