Dynoed the cobalt today N/A
Old Aug 8, 2015 | 06:09 PM
oh ****.
I dont think anyone has ever used one of those manifolds on an NA car. Im interested!
Old Aug 8, 2015 | 09:07 PM
sS07NA's Avatar
I've seen it on a 2.2 but no dyno sheet.. i'mma test and tune for you guys, tired of no proof or results
Old Aug 9, 2015 | 12:25 PM
Twoozofjuice's Avatar
Originally Posted by Jesse
With all the typical bolt-ons, no tune was 148whp and tuned was 163whp both with an unlocked torque converter. My tune was aggressive though and I had access to better fuel. Now I'm 4000ft altitude and with half ethanol I barely eke out 165hp with the converter locked. 155hp unlocked. It sucks.
How are you making it stay in gear during a dyno pull?
Old Aug 9, 2015 | 01:57 PM
Nice
Old Aug 9, 2015 | 03:40 PM
Jesse's Avatar
HPT scanner tools. You also have to change a setting in the tune or it won't work. Will post a screenshot when I'm home
Old Aug 9, 2015 | 04:33 PM
Jesse's Avatar
To be able to command gears with HPT you need to MAX those two fields(MAX RPM/MAX VSS), and ZERO OUT the (Downshift max VSS) table. Then you can command whatever gear you want with the scanner open. You can also command a full lock of the converter in any gear, but remember to unlock it when you come to a stop or the car will die.
Old Aug 10, 2015 | 12:27 PM
GBRunner24's Avatar
Awesome numbers!!
Old Aug 10, 2015 | 01:42 PM
What am I supposed to set them to? When maxing them
Old Aug 10, 2015 | 02:00 PM
Dipped_Cobalt's Avatar
1 million each
Old Aug 10, 2015 | 02:19 PM
Jesse's Avatar
Originally Posted by Dipped_Cobalt
1 million each
This. Even 10,000 works. HPT will correct them to the maximum they can be.
Old Aug 13, 2015 | 10:51 PM
  #36
OlympicSS's Avatar
Im super interested to see how this goes! I have been wanting to do an NA build with an intake manifold like this, but was always concerned about losing power with the design of the runners on it. Did you just use a regular LSJ intake for the manifold? Did it require any modification besides removing the washer fluid tank?
Old Aug 14, 2015 | 05:29 PM
  #37
sS07NA's Avatar
A buddy did the work for me, he removed the tank just to make room for my velocity stack filter and made a intake that goes straight down to the right. lsj oil dipstick, diff hose for evap, relocated intake air sensor. I think that's it
Old Aug 14, 2015 | 05:30 PM
  #38
sS07NA's Avatar
Sorry I've been lagging on this, I can't find a guy to tune my car yet
Old Aug 14, 2015 | 10:43 PM
  #39
OlympicSS's Avatar
Hurry up! (;
Haha, I think all of us are excited to see how this turns out. Do you have plans to port and polish the head, throw some springs, retainers, and cams in there?
Old Aug 14, 2015 | 11:38 PM
  #40
Get hptuners and remote tune
Old Aug 15, 2015 | 04:56 AM
  #41
sS07NA's Avatar
plan on going with cams i think.. someone is selling them but Idk it's my daily.. I think I found a tuner too
Old Aug 16, 2015 | 03:05 AM
  #42
sS07NA's Avatar
First snag, oil change now takes triple the time because of the runners blocking the oil filter
Old Aug 16, 2015 | 03:08 AM
  #43
Lol did you have to take the manifold off?
Old Aug 16, 2015 | 10:51 PM
  #44
cluelessk's Avatar
What a waste of time.
You'd see better results by losing a few pounds.
Old Aug 17, 2015 | 04:06 PM
  #45
sS07NA's Avatar
Probably is but I'd still like to see some results. Im at 145lb and if u saw my car its down to the bare minimum I don't keep anything extra. I removed all extra weight arm rest, spare tire, rear headrest, passenger seat haha etc...
Old Aug 17, 2015 | 04:15 PM
  #46
all that wont help your dyno numbers.
whats your track times?
Old Aug 17, 2015 | 06:02 PM
  #47
sS07NA's Avatar
haven't been to the track
Old Aug 17, 2015 | 07:48 PM
  #48
Keep it to the streets
Old Aug 18, 2015 | 12:52 AM
  #49
no_ss's Avatar
Gut the back seats and all the carpeting
Old Aug 18, 2015 | 05:50 AM
  #50
sS07NA's Avatar
Thinking about it^^^^^
