engine break in
engine break in
Hey guys, Im new to cars in general so this might sound dumb!
So I am about to get myself a 08 cobalt sport
this is my first "brand new" car and I was wondering how you guys break in your engine and what is the optimal way of doing it.
I found an article here : http://www.mototuneusa.com/break_in_secrets.htm
It seems to propose a new way of breaking your engine in and it seems logical but again im an idiot when it comes to cars.
thanks guys for the input
With my 2.2 I didn't go over 55mph for the first 100 miles, which was easy because I never had to travel on the interstate. Then for the first 1,000 miles I didn't accelerate quickly or gun it, and still rarely do this. Then, maybe it's just me, but after about 1,000 miles it seemed like the engine started running better and I was able to accelerate a bit quicker.
hmm... you posted this twice... i replied in the other one, but I'll say it again here:
i have a 08 sport i have 1910 miles on it. just don't gun it till you have at least 1-1500 miles on it. (well ok I admit i did gun it a few times...) that's what I did. then again my dealer said the engine was already broken in sooo I dunno.... *shrugs* and yes this is my first brand new car too
this car is awesome! just word of advice though go easy and a bit slow on 3rd and 4th gear. It likes to grind sometimes especially if the engine is cold. But other than that i have no complaints. as for that website... i have no idea cause i was/still is like you
Engines are pretty much broken in from factory, don't really need to worry about it. If anything, don't be too nice to it. Rings need some nice WOT to seal. But like I said, everything is good from Day 1.
Even if the engine was broken in fully from the factory (which I don't think they are) you still need to break in the clutch if it's a 5 speed. This is important unless you want to have clutch problems later on.
Just don't worry about and drive the car however you normally would.
There will be many different opinions on this, just drive it like you normally would not to fast and not to slow and vary the speed. You want to at least let the clutch and cat. break in the first 500 miles or so. This is was I've read and have been told.
I drive my 08 5spd manual like it was my first car. (I do take well care of it though
You've got a 100,000 mile warranty and 36k on everything else. I'd say drive it however u feel most comfortable driving it!
yeah xtorted.. your right .. I do have a pretty good warranty on it
well thanks alot guys for all the input.
What I will do is this:
I want to make sure I break it in properly... most people here told me to drive it like I would normally do,others told me to gun it to create more pressure on the piston(which is what I believe makes sense, and others telling me to go easy till 500miles), but to be on the safe side and make sure its well broken-in this is what i thought,
I will drive from the dealer to a long straight i know off. this will take around 10mins.. just enough to warm the engine up and all the fluids
from there, I will vary rpm, and also let the engine break the car so I create a vacuum in the piston.
After that I will let it cool down and then go around 30-45% throttle for like 15-30 secs and let it rest by driving slowly , then I will go 50-60% throttle for 15-30secs and again let it cool down by driving slowly around and also not using the clutch-in break to stop but instead let the engine slow down on its own.
eventually I will work myself up towards WOT for the full length of the straight and then let it cool down before going home.
I will repeat the day after and then go for an oil and filter change
Im pretty sure after that my car should be all set up and break-in
patooyee
Oct 1, 2015 01:07 PM
