Engine revs low and lower....
Noticed lately that if I'm at ideal(700- 800ish rpm) sometimes the car with rev low(600ish rpm) and my gauges will dim and get brighter then low again then normal when I tap on the gas..
whats the cause??
thanks
whats the cause??
thanks
No new alternator. It's totally normal for the lights to dim if the engine bogs because the alternator has to be spinning at least the normal idle speed (around 850 rpms) so if the engine bogs lower than that, the alternator isn't spinning fast enough to produce enough electricity. As soon as the engine speed picks up again everything is fine. And yes the MAF is the the sensor in the intake. Make sure you get MAF cleaner for it though, it can be found at autozone
is this a decent how-to on the way to use the cleaner?
does anyone have any tips?
HOW TO CLEAN A MASS AIR FLOW SENSOR / METER , M.A.F. SENSOR !!! - YouTube
I know this isn't a cobalt but same rules apply.. right?
patooyee
Oct 1, 2015 01:07 PM
