Full CAI VS. SRI
Old Jun 12, 2008 | 02:34 AM
kush's Avatar
Full CAI VS. SRI
Is there a difference in performance or sound with CAI vs. SRI? And how do GMAPP's compare to others?
Old Jun 12, 2008 | 02:37 AM
EceSSiveMod's Avatar
first off its gmpp....to expensive
cai in usually down in the engine bay usually sucking up air from underneath the car
sri sits on top pretty much and sucks all the air up around the motor
sri MIGHT give u 2 or 3 more hp but in all honesty theyre pretty much the same thing
Old Jun 12, 2008 | 02:38 AM
omgshesaboy's Avatar
im surprised this question is asked more often on here
Old Jun 12, 2008 | 02:41 AM
helo fellow ohioian haha
Old Jun 12, 2008 | 02:46 AM
HEYYY! im moving to kent next year right by akron
Old Jun 12, 2008 | 02:49 AM
PenguinPIE's Avatar
sound difference.....some say cai louder some say sri louder........i'd say they are pretty similar (GMPP maybe the quietest tho)
Old Jun 12, 2008 | 02:51 AM
REIGN SS's Avatar
Original Hayden Fanatic
Yes there is a big difference, when I got my Injen I first installed it as a SRI I saw Intake Air Temps that were ~15* above ambient air temperature, and ~10* over the stock air box.
Changed it over to the CAI, IAT dropped back down to ~2-3* above ambient, and the same or lower then the stock air box.
Yes, you will get a slight increase in sound volume going SRI over CAI, but Performance > Sound IMO
Now, I cannot speak for the GMPP IAT's as it does have a shield in the engine bay which I'm sure blocks some heat where the Injen does not, but I personally would go with a CAI over the GMPP
Old Jun 12, 2008 | 02:54 AM
lowbalt06's Avatar
i cant agree with you anymore.. even switching you notice the difference right away.. imo..
i run a sri during winter and a cai during summer. injen ftw.
Old Jun 12, 2008 | 03:17 AM
Jn2's Avatar
Jn2
ive ran them both, felt no diffrence
Old Jun 12, 2008 | 10:13 AM
lowbalt06's Avatar
a turbo will have that effect lol...j/k
Old Jun 12, 2008 | 04:04 PM
joeyblaze's Avatar
you guys do know the GMPP is not SRI its a CAI, the Box where the filter sits is sealed by the hood. the air is drawn via the stock pipeing from the fender wall. so the GMPP is a CAI
the GMPP is not quite at all, its very loud and u can def feel the power added even tho its prob only like 2-3 hp
Old Jun 12, 2008 | 04:08 PM
hatrickstu's Avatar
would you rather be sucking up ambient air or under hood air? i prefer cool air, maybe im different
Old Jun 12, 2008 | 04:36 PM
joeyblaze's Avatar
but u must keep in mind most CAI intakes have much longe paths and many more bends which hurts performance
Old Jun 12, 2008 | 04:43 PM
BlackMachine's Avatar
which is better? cai or sri?
Old Jun 12, 2008 | 04:46 PM
invisible's Avatar
Cai Ftw!!!!
Old Jun 12, 2008 | 04:53 PM
hatrickstu's Avatar
so long cool path < hot short path?
Old Jun 12, 2008 | 05:10 PM
PenguinPIE's Avatar
or get the injen intake which is a CAI that can be converted to SRI so you can try out both on ur own
Old Jun 12, 2008 | 07:42 PM
FF_ace's Avatar
CAI i blieve would give you more power but not very much. the cooler the air is the more dense it is there for meaning more air which means more power correct me if im wrong guys.
Old Jun 12, 2008 | 09:59 PM
maverick0716's Avatar
When you're driving down the road, SRI intakes do not suck in hot air......they get the cold air that comes out of the fender well. I've tested this on my K&N SRI (with heatshield) with my MSD Dashhawk.....at idle, while not moving, the air temp will rise quite significantly......BUT while the car is moving, the IAT drops way down to the ambient air temperature.......so a CAI would have no advantage while the car is moving (and that's all that really matters).
Old Jun 12, 2008 | 10:05 PM
ilovecars's Avatar
i still like cai better i like how it snakes around
if i realy wanted a super short ram intake just attach the filter to the throttle bodie lol
Old Jun 12, 2008 | 11:39 PM
REIGN SS's Avatar
...I disagree, I saw IAT's 15* above ambiant while moving using a SRI Injen
Old Jun 12, 2008 | 11:45 PM
hatrickstu's Avatar
i just didnt feel like arguing....
Old Jun 13, 2008 | 02:55 AM
I don't care if you disagree.......I'm telling you what I saw on my Dashhawk with my K&N SRI..........maybe the Injen really sucks as an SRI and is only good as CAI.
Old Jun 13, 2008 | 03:26 AM
Jn2's Avatar
Jn2
well k&n has that plastic heat shield, im sure that helps with the heat a bit, but hell when i had my GMPP i would touch the shield and it would be hot, hell touching the aluminum piping from the GMPP was hot too, remember that the air might come in at a certain tempature but the piping is hotter closer to the engine..meaning it will heat up, personally wether you go short or cold, the intake wont make that much of a diffrence, only good for 2-3 ponies in our cars
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
nathan112i
Sep 30, 2015 07:12 PM
