Fuse box help
Old Apr 15, 2011 | 08:01 PM
06.ss.sedan's Avatar
Thumbs down Fuse box help
So I have a 06 ss sedan. I have 2 cig lighter ports and the only one that works is the one by the e brake. The one below the climate controls does not. I looked at my fuse box and the diagram shown matched nothing in the fuses itself. I was wondering if anyone knew what fuse it is that controls the accessory port. Cause I have no clue and would like to have both of them working.
And we don't have a auxiliary port anywhere do we? All I want is to use my iPhone's built in iPod instead of having to switch CDs all the time. I know they make adapters but they are a lot more then a aux cable. Any help would be great. Fixing the non working accessory port would be good enough for now.
Old Apr 15, 2011 | 08:05 PM
Grave's Avatar
Which fuse box did you look at? I'm assuming the one on the passenger side below the dash?
Old Apr 15, 2011 | 09:16 PM
Yep thats the one. Is that the wrong one to look at for the accessory port?
Old Apr 15, 2011 | 09:20 PM
madmark's Avatar
there maybe the one under the hood as accessory or cig, check that one as well
Old Apr 15, 2011 | 09:28 PM
evil ss's Avatar
its normaly under the hood because that fuse also powers the OBD2 plug
Old Apr 15, 2011 | 09:47 PM
C_A_D88's Avatar
Its listed as LTR under the hood, and I dunno bout other years but the 12v outlets in my car do not run on the same fuse as the obd2 port , the trunk lock and light run off the one by the e brake tho
Old Apr 15, 2011 | 10:12 PM
evil ss's Avatar
I know on most modern gm cars the cig fuse powers the obi port because I run into that problem quite a bit when trying to scan a car and get no comunication
Old Apr 16, 2011 | 12:18 AM
YelloEye's Avatar
Sounds to me like your outlet under the HVAC controls isn't hooked up. Since the other outlet works fine I'd make sure the other one is plugged in behind.
Old Apr 16, 2011 | 03:12 AM
Jeffs 06SS 2.4's Avatar
I have the exact same problem.
Old Apr 16, 2011 | 11:01 AM
Thanks for the help guys. I'll take a look under the hood as well as behind it to see if it's plugged in too. And I can't figure it out I'll be posting again, lol
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
