it happened again
Old Mar 14, 2009 | 07:29 PM
wesg631's Avatar
it happened again
Its weird im cruisin around 60 then i floor it and the car acts like its shifts up to early i have an auto btw any reason it would do this all i have is a k&n intake
Old Mar 14, 2009 | 10:34 PM
DynamikGT's Avatar
That's what happens when you have the car shift for you?
Old Mar 14, 2009 | 10:36 PM
JPizzle's Avatar
Do you mean it doesn't take it close to redline?
Like it shifts at 4,000 RPMs????
bryce712's Avatar
should shift around what 72 or so
JPizzle's Avatar
No... That's really high!
My old 2.4 (manual) 's redline was at 6,750
Old Mar 14, 2009 | 10:40 PM
bryce712's Avatar
i was talking mph lol
Old Mar 14, 2009 | 11:19 PM
_UnLiMiTeD_'s Avatar
lol even i clued into that one
Old Mar 15, 2009 | 02:57 AM
HunterKiller89's Avatar
it should indeed shift between 68 and 74moh, depending on tire size. BTW, it wont pull to redline if you're anywhere under 100% WOT. 90% throttle will shift the car before it even kits 6,000rpms
Old Mar 15, 2009 | 09:19 AM
riko540's Avatar
They are right if your not 100% WOT it will shift earlier than expected. Its the problem you deal with when you drive an automatic.
Old Mar 15, 2009 | 08:33 PM
wesg631's Avatar
Ok i was cruising about 65 the went to 100% wot then it shifted around 5500 rpm
Old Mar 18, 2009 | 04:50 PM
Evil C's Avatar
I seem to have the same problem it dosn't hold the shifts as long as it should before or after i had it tuned and supposedly my shift points were bumped up to 7100 er so WOT.
Old Mar 18, 2009 | 04:54 PM
sport08's Avatar
is your floor mat under your pedal at all if so the pedal could just be hitting the floor mat and not going all the way down to WOT
Old Mar 18, 2009 | 05:29 PM
Hockeyman's Avatar
your problem is that it's an auto
Old Mar 18, 2009 | 05:57 PM
you sir, fail. please leave
Old Mar 18, 2009 | 11:08 PM
wesg631's Avatar
i just got he b&m shift plus installed and it seemed to help out alot maybe its just our sucky trans
Old Mar 18, 2009 | 11:13 PM
DynamikGT's Avatar
The trannies in these cars are fine...
Old Mar 18, 2009 | 11:17 PM
wesg631's Avatar
the shifts are slow order a b&m shift plus put in stage 1 or 2 and then back to stock and tell me that the shifts dont suck
DynamikGT's Avatar
Or I could just get a real tune.
or a manual.
Old Mar 18, 2009 | 11:20 PM
wesg631's Avatar
yea you could
Old Mar 18, 2009 | 11:23 PM
blackbolt89's Avatar
how is that shiftplus?
Old Mar 19, 2009 | 04:48 AM
the tranny is programmed for a smooth shift, thats all. just because its tuned more for comfort than performance doesnt mean it sucks...
Old Mar 19, 2009 | 04:57 AM
Iturbo's Avatar
Old Mar 19, 2009 | 06:25 AM
wesg631's Avatar
shift plus is awesome i suggest it if you just want to hook up a couple wires instead of gettinga tranny tune
Old Mar 19, 2009 | 06:34 AM
Tundraboarder666's Avatar
Mine shifts around 74 mph at 100% throttle... thats weird dude
Old Mar 19, 2009 | 11:34 AM
Turbo06Sedan's Avatar
Our sucky trans?
Tell that to myself and the other auto's that are 260+whp, 330+ftlbs on the stock trans.
