Header advice
Old Sep 9, 2007 | 12:49 PM
baltracer173's Avatar
Header advice
I got the GMPP header yesterday and tried to install it but couldnt ge the bolts off of the downpipe end. My friend keeps tellign me to get a ceramic header instead but i dont want to spend more. Has anyone had good luck with the GMPP header and seen performance gains. It prety much looks exactly like the stock one.
Old Sep 9, 2007 | 01:08 PM
martinsmu's Avatar
I felt a little extra boot in the bum. But iam sure they are more performant headers out there.... just depends how much you want to keep ure gm warranty and ure guranteed quality and fitment with gmpp. Where others....
Old Sep 9, 2007 | 01:13 PM
Element2.4's Avatar
If you cant get the bolts off go to Home Depot and get some liquid wrench. It will help you alot.
You should be fine with that manifold though. Just make sure you get a free flowing Down pipe. I think the header is over rated on these cars.
sugardaddy2885's Avatar
Mine were a bitch to get off too. I think if they were easier to get too it wouldnt be as bad.
Old Sep 9, 2007 | 01:14 PM
Super_SS's Avatar
OFF TOPIC
u bout the car not evem 2 days ago and u got the intake all ready..hahaha..just cant drive stock can u
Old Sep 9, 2007 | 01:16 PM
Element2.4's Avatar
Originally Posted by Super_SS
OFF TOPIC
HAHA. I have someone locally who is trying to sell a borla exhaust also. I think im going to get it
Old Sep 9, 2007 | 01:19 PM
madmark's Avatar
liquid wrench works pretty good. i had a hard time getting them out for my friends car and one of the heads on the bolt snapped. i got another one replaced under warranty (gm tech) and put it on as well as an exhaust. to me it didnt seem like it made any improvements in power wise
chiva anyone?
Old Sep 9, 2007 | 01:20 PM
I was just thinkign about having the dealer install the header because i still need to order the gaskets for it and they would ahve a much easier time doin it. I kno it costs money though. A 2.5" dowpipe with a high flow cat would be the best bet in replacing the stock right?
Old Sep 9, 2007 | 01:21 PM
Element2.4's Avatar
You should be able to re use both the gaskets. I would say 99% of people do and alot of exhaust dont leak.
Old Sep 9, 2007 | 01:23 PM
Whats the best brand of downpipe to get to go with this system
Old Sep 9, 2007 | 01:27 PM
Element2.4's Avatar
I would honestly recommend the ZZP Dp. You wont be disapointed with it.
Old Sep 9, 2007 | 01:28 PM
should b able to order that at a local tuner shop shouldnt i and then they can install that and header at same time
Old Sep 9, 2007 | 02:02 PM
Element2.4's Avatar
You can get it from www.zzperformance.com. You should get it all installed at once. Dont pay more then 100 bucks labor for both to be installed.
Old Sep 9, 2007 | 05:03 PM
wordsthatiwrote's Avatar
If you do end up getting that Borla Exhaust, could you put a video of it? Ive been looking at that too.
Old Sep 9, 2007 | 11:35 PM
Element2.4's Avatar
You have a GTO also?
Old Sep 11, 2007 | 02:20 AM
REIGN SS's Avatar
Original Hayden Fanatic
I had to cut the bolts off my LS when i put my catback on, and that was only after about 10000mi, way to go GM
Ill let you know how the ZZP downpipe works out, ive got it sitting on my living room floor & im going to install it this weekend.
Old Sep 11, 2007 | 10:08 AM
yoppzilla's Avatar
should of just got the header downpipe combo from zzp
Old Sep 11, 2007 | 10:28 AM
marerick007's Avatar
I wouldn't reuse the gasket...a few bucks in the beginning could save you much frustration and money in the long run, esp if you have to worry about emissions testing where you are.
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
DocSvensk
Sep 27, 2015 02:24 PM
medic710
Sep 6, 2015 08:53 PM
