header/downpipe
If you haven't realized, tuning is EXPENSIVE
Last edited by JKennedy1612; 09-04-2007 at 01:36 PM. Reason: Automerged Doublepost
Wow I'm confused
If you installed the ss/sc injectors, I would go back to stock. Get all your parts for your sc swap before installing some of them. It will be easier on the car, as well as you.
yeah I agree. Just go back to stock until you're going to put everything together. THEN get a tune
yea...i mine as well get it tuned when i have all the lsj parts...i have the m62 eaton, stock pulley, injectors, belt, bosch i/c pump and the 2.0 intake manifold on its way...i will save alot of money by tuning it all at once...
ok just got back from the shop b/c....my check engine light came on due to got an header and downpipe with cat installed. They ran a diagnostics test and 3 codes came up. here are the codes P0420( cat efficiency below thershold).. P0171 ( system too lean)..P0300 Random multiple misfire..The mechanice at shop thinks that it could be a bad cat...b/c i got the 1/3/4 midleanth header and a 3inch downpipe with 2.5 exit from ZZP...it was recommended from couple of guys on the site b/c im supercharging it soon...so he also thinks that i might need a tune/reflash cause its a newer model...so what u guys think??
Yeah i had to put on a little act like I never modded my car and had no idea what was going on. Later after they reflashed it to factory tune I took it back to my tune shop and had it reflashed back the the performance tune for free!
#36
im not gonna get it tune until imn ready for boost...but i heard that tune time is down in nj towards the sure...im probably not gonna make thewre w/ the sc on and prob it will blown up b4ore i get there lol....any other other tuner places in BUcks county.pa/philly area
compucarnut
05-11-2008 04:53 PM
