Header/Manifold gasket
Old Dec 5, 2013 | 02:48 PM
Pitbull2o08's Avatar
So I have the Badmab for my LE5. My dealer has the LSJ/extruded-honed gasket and the LE5 gasket. Which one should I get? Thank you
Old Dec 5, 2013 | 04:30 PM
nhanson's Avatar
The one that matches your port...so the LE5
Old Dec 5, 2013 | 04:56 PM
Damn it. I just had them order the LSJ one.
Old Dec 5, 2013 | 06:11 PM
LSJ won't work at all? I figured it's the same, just the primaries on the header are bigger.
Old Dec 5, 2013 | 08:19 PM
thejoey12's Avatar
The lsj will work fine
Old Dec 6, 2013 | 03:07 PM
Is one better than the other? I ordered then both from GM just in case.
Old Dec 6, 2013 | 03:28 PM
thejoey12's Avatar
Naaa same basic principle really...go with the lsj one though
Old Dec 6, 2013 | 06:24 PM
nhanson's Avatar
In reality it doesnt matter but I would prefer the LE5 one. That way you have more gasket
Old Dec 6, 2013 | 06:28 PM
ItalianJoe1's Avatar
LSJ gaskets are awesome MLS gaskets, and will seal up just about anything as long as the flanges are straight. Having "less gasket" isn't really a factor, as it uses raised seams basically to compress into the mating surfaces, it's not relying on large area but rather good pressure and a spring steel to maintain sealing even with temperature/pressure changes.
Interesting! I didn't know it was thicker!
Old Dec 8, 2013 | 02:52 PM
So LSJ then?
Turbo Johnny
Feb 21, 2019 09:41 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Macgyver2484
Sep 2, 2015 05:44 PM
