a header question
Old Feb 18, 2010 | 07:21 PM
wesg631's Avatar
a header question
how many people have just used a stock exhaust manifold gasket when installing a header?
when i went to install mine with a stock crap gasket and i saw that it kinda canceled out the effect of the header.
so i called cti and they gave me they number which for an embossed copper gasket from sce gaskets it is 9431 from summit it cost 21 bucks shipped
Old Feb 18, 2010 | 07:28 PM
slowswap's Avatar
Stock header gasket is more then sufficient. You can always use some copper spray on stocker if you really wanted too.
Old Feb 18, 2010 | 07:32 PM
wesg631's Avatar
i'll find my camera and show that the stock gasket cuts the flow into the header at least on my header
Old Feb 18, 2010 | 07:34 PM
slowswap's Avatar
Exhaust gasket fits the stock head port, which will restrict flow. So unless you're porting your head, theres no need for a larger exhaust gasket.
Old Feb 18, 2010 | 07:48 PM
wesg631's Avatar
stock lined up with bottom of header tubes
copper sce gasket on header
copper and stock compared
there is about an 1/8 inch of stock blocking the header tube
so why put a header on if you are just gonna block airflow through it
Old Feb 18, 2010 | 07:57 PM
slowswap's Avatar
You're not blocking airflow. You're comparing the wrong side lol. The factory gasket does restrict flow on the head side. If you're not restricting flow on the head side, the header side is null and void.
Think outside the box.
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
