Header questions!!
Header questions!!
I'm still with the stock, as far as engine, 2.4 LE5, with the exception of an intake tube..
I'm wanting the Hahn Racecraft MaxFlow Downpipe/Cat and the 3” Stainless Steel Exhaust System street version.. I was wanting the Stainless Steel Shorty Header from Hahn's as well, but it will only fit the 2.0s..
Is there another good header that can be used other than stock so I can still use the Hahn Racecraft MaxFlow Downpipe/Cat and the 3” Stainless Steel Exhaust? Or at least a better solution with a good sound?
05-10 CHEVY COBALT EXHAUST - BOLT ON - (ALUMINIZED - 2.5 IN)
the header should fit your car just email or call hahn.
I should have seen that before I posted.. I was looking at the 2.5 inch exhaust, just got lazy and copied and pasted the heading for the deal they have going on..
I'll give them a call when I get a chance and see if it will, under the description it says, "*This header is designed to fit exclusively on 2.0 Cobalt and Ion RedLine. It is not compatible with 2.2 or 2.4 liter engines." Maybe they will have something else that is not thrown out there on their site.. Thanks..
Header should fit without a problem. As said 3" exhaust is way to big and you don't want that mandrel exhaust. I've seen people say they don't fit properly plus you would actually be downgrading because stock exhaust is stainless and that one is aluminized. Look at ZZP's catback for the best bang for your buck.
z28addiction
Sep 28, 2015 12:03 AM
