Help
Old Apr 14, 2007 | 08:55 PM
074DOORCOBALTSS's Avatar
Smile Help
Can yall give me the cheapest and easiest mods i can put on my 2.4L? any help will be very appeaciated!!!
Old Apr 14, 2007 | 09:02 PM
g5mike's Avatar
start with an intake and catback,then maybe get a header/DP, check out our vendor index or the 2.4 performance section
Old Apr 14, 2007 | 09:06 PM
chevysalesman614's Avatar
open it up a bit with intake and exhaust ( header, catback) then maybe stock SS S/C injectors (34lb/hr) *note that injectors require 2.2L wiring harness and a retune.
when you get all that done, we'll go from there
Old Apr 14, 2007 | 09:08 PM
DTM2188's Avatar
Agreed with what both these guys said, intake and exhaust to start off with.
Old Apr 14, 2007 | 09:09 PM
Thanks about how much am i looking at for header, an catback? an what is the best catback to go with?
Old Apr 14, 2007 | 09:11 PM
as far as a catback, i suggest u go to an exhaust shop and make you one, using a magnaflow muffler.
Mine was only $340
Old Apr 16, 2007 | 02:24 PM
rlinden86's Avatar
heres exactly what i bought and did. i got the gmmp performance exhaust with angle cut tip for 505 including tax. then bought the CA header and DP that was 570 including tax for both. bought the gmpp intake that was 290 with tax. and now i picked up the 2.0 stock injectors from a guy for 20 and traded my top half air box to him for them. and bought the 2004 cavi harness for them that was 65 new. should be around 1500 or 1600 or so which isnt to bad id say. then you have to tune it after injectors for sure.
ryan.
