Help Quick
Old Feb 28, 2007 | 10:57 PM
Lovethesox's Avatar
Help Quick
im putting in my cobalt addiction header right now and its pushing against a pipe causing it to leak i think coolant not positive but i got it all in turned the car on and it starts to gush out anyone know what the **** im doing wrong?? please help!!!
fixed it
Last edited by Lovethesox; Feb 28, 2007 at 10:57 PM. Reason: Automerged Doublepost
Old Feb 28, 2007 | 11:04 PM
elmstreet's Avatar
what was wrong
Old Feb 28, 2007 | 11:49 PM
Lovethesox's Avatar
This is what happend
supposedly there was a fittment issue with a coolant line in the 2.2s but no 2.4s as well i had to dremel a dip in one of the tubes on the header so it wouldnt put pressure on the line because it was causing it to leak EVERYWHERE so needless to say 5 hours later ***** on and its chill i like it def got more pep it climbs in third quite a bit quicker now
i just hope the people at Cobalt Addiction send a note or something with the header so that people dont go through the **** i just went through boy am i glad thats its on and done its like 11 degrees out and working on your car that cold NOT FUN
but a great product non the less
Old Mar 1, 2007 | 04:19 PM
WhiteSSBalt's Avatar
Not a Sebring
mine did the same thing when I installed my CA header. When I started the car, the first thing I heard from my friends wasn't "nice, sounds good" it was "oh **** turn it off turn it off!" lol. It just took a little pee pee of coolants on my friends driveway, but I checked the coolant levels and the coolant temp on my gauge display, and everything was fine. I took it for a spin around the neighborhood and everything seemed fine. I installed everything back in Nov., and that little leakage deal hasn't happened against since. I think you probally just bumped the release valve thats under the car, b/c I asked the same question on .com when this happened to me, and thats what I was told. No worries, everything should be just fine.
Old Mar 1, 2007 | 04:27 PM
06blackg85ss's Avatar
also if there is a fitment issue... you can rotate the coolane pipe in towards the block and that will give u the clearance you need.
Old Mar 8, 2007 | 06:56 PM
Lovethesox's Avatar
so im gonna try to rotate that coolant line tomorrow any ideas for the best way of doing this i really dont wanna pop a seal or damage anything ya know?
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
Tdubbs
Oct 13, 2015 02:31 PM
The Rookie24
Sep 20, 2015 04:33 PM
toledobalt
Sep 2, 2015 01:19 PM
