How hard is it to pull just the motor from the cobalt sports?
Timing chain broke and know i have a hole in my oil pan.. going to do a full rebuild and put some forged internals. do i pull the engine or do i remove the head in the engine bay? new to seriouse motor stuff lol the most i have done so far is S/c and such. LEt me know :)
On the automatics, engine will come right up and out as long as you remove the crank pulley first, theres about an inch of clearance against the frame rail. Taking the head off before hand can make life easier. You will require an assortment of specialty sockets though. Torx, reverse torx are two that i can think of off hand. Torque angle meter is essential for rebuilding.
I posted this pic for the nay sayers last year lol I will warn you though, manual transmissions are a different story because of the clutch. http://www.hostthenpost.org/uploads/...a65a21d8db.jpg |
Spawne has done tons of these engines (4 to be exact) .. He has good advice
Originally Posted by TStone
(Post 7468163)
With a manual trans cant i just unbolt the tran and pull the motor out?
Originally Posted by sheape
(Post 7468223)
I don't see you being able to pull just the motor through the top with a manual. You should be able to pull the engine and trans as one tho. You will have to pull the fuse box, and I don't think you can keep the ac together either.
I have a LE5 bare block with 5000 miles on it. $300 plus shipping
It's not hard to drop everything out the bottom, that's how i've done them in the past. Set the engine and trans as a unit down on a cart, lift the car high, slide it out the passenger side wheel well. Easy enough without a lift.
Pulling out an engine is not too difficult as long as you have all of the right tools and equipment
Originally Posted by ItalianJoe1
(Post 7468260)
I did mine (auto) through the top and it went well.
We just dropped my buddies LSJ through the bottom (engine, trans and cradle) |
drop whole cradle with engine and trans
raise car up, slide drivetrain out thru front |
Thank you all for the advice is there a form post that can show me how to remove from the bottom? if not does anyone have some pictures and details?:)
2 Attachment(s)
(Post 7468567)
The car was assembled by lowering the body onto the cradle, so that is the simplest way to remove the engine. But first thing I'd do if i were you is drop the oil pan to see what's really going on. |
How?
(Post 7468597)
How?
dont want to thread jack but where and what is build book?! i keep reading about it but idk what it is! thanks...
I have a build book I can sell. I don't have an LSJ anymore.
well i have a 2.4 and lsj might help a little but where can i buy one from..??
CED still has them I found one on eBay when I got mine ended up being through Jegs.
I picked up a chilton manual yesterday, although it has good info, I find myself in the gm book until I hit a snag, then I'll check out the other
