K & N Drop In Filter
Old May 14, 2006 | 03:59 AM
snobird's Avatar
ok guys i was considering cai or sri but i dont want cels comming on will the drop in filter cause a cell? i dont think it should but just wondering! also will it really increase hp since it is still using the stock box or what can i expect? Thanks
Old May 14, 2006 | 05:01 AM
Mahadigus's Avatar
I had one b4 I got my Injen and it never threw cel's. As for noticable power gains....not likely although I never reset my pcm after I installed mine. With my injen I've had it for about a week and have had no cel's with that either. I can safely say that the injen cai has made quite a difference and was worth every penny. Hope this helps a bit.
-Mark
Old May 14, 2006 | 05:05 AM
snobird's Avatar
thaks im just trying to decide cause the kn is only 25 bucks with my discount
Old May 14, 2006 | 05:10 AM
Mahadigus's Avatar
Well for 25 bucks it's well worth it... the fuel savings alone will pay for the filter...My economy went way up after I put mine in.....As for the power end of things K&N claims that a dropin will give roughly 2-4% increase over stock so maybe if you lucky 5-6 flywheel hp.
Old May 14, 2006 | 05:19 AM
snobird's Avatar
but no derease at all correct jsut increase in eevrything especially gas millage and if anybopdy needs one pm me
Old May 14, 2006 | 05:24 AM
Mahadigus's Avatar
Yep that sounds about right.
Old May 14, 2006 | 05:26 AM
snobird's Avatar
thanks
Old May 14, 2006 | 06:16 AM
NJHK's Avatar
No CELs with filter changing.
I don't understand why people are getting CELs with intake upgrades anyways...sounds weird to me.
Old May 14, 2006 | 06:21 AM
snobird's Avatar
njhk i have heard something about the ecu or computer unit whatever they call it in the ecotech is very sensitveto change as in a honda i can add full exhuast and remove the 02 sensors no no cell
Old May 14, 2006 | 06:46 AM
NJHK's Avatar
I can understand it throwing a code cause of something drastic done but you're changing the intake. I thought I heard somewhere that you guys have MAF sensors instead of MAP sensors, which might be why it's acting up.
I think another way of figuring out this problem is by actually knowing what code is coming up. People keep saying "I have a CEL" but don't know the code.
Also, the comment about hondas removing O2 sensors, that depends which sensor you're talking about. If you remove your 2nd O2 sensor, it's not reading exhaust flow...it more than likely reacts to high emmissions rather than low.
Old May 14, 2006 | 06:55 AM
snobird's Avatar
on my civic before i turned for obd 2 to ob1 i removed both no light it was that way for about 2 days so not sure if long enough for it to come on also people can check ther codes by gettting a piece of wire and runiing into the place where the plug the pc crap up under the dash their is a little harness their run a peice of wire to say first and last pin sokect i bleive and watch how many times your light flashes then any auto store can tell you based on how many times it flashes
Old May 14, 2006 | 07:04 AM
NJHK's Avatar
OR just take it to a auto store and they can do a complete scan for free.
Old May 14, 2006 | 07:09 AM
snobird's Avatar
be sure its auto zone as advanced tried to charge my friend one auto zone advertise it
Old May 14, 2006 | 07:31 AM
NJHK's Avatar
Wierd. I've been to both and they did it for free.
Old May 20, 2006 | 04:50 AM
snobird's Avatar
dose the drop in change the sound at all
Old May 20, 2006 | 08:36 AM
avro206's Avatar
skip the drop in----I picked up 2 mph and 0.1
Drop in will get you zilch. Spend some cash and go faster
I had no CEL
Old May 20, 2006 | 08:37 AM
avro206's Avatar
Drop in will get you zilch. The facory air intake routing is pretty restrective. Spend some cash and go faster
no_ss
Oct 18, 2015 11:58 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
grampss
Sep 27, 2015 08:51 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
