Lets discuss a 2.4 NA Build
I personally wouldn't worry about the head too much on an NA build because your cam lift is your limiting factor but some machine shops can hog out the head if you wish.
An E85 conversion would be simple as well on an NA build. Well within the limits of the stock fuel pump.
I can't see 220whp+ without cam regrinds imo.
No, just the stupid kid thats allowed more play money than most from his better half.
Honestly though, you won't regret going the big cam route. A cammed four banger is "megalolz" at stop lights in my opinion.
hey im just tossing ideas out there..what about custom intake/bigger thortle body (witt?)
and as for na build..me and reign where discussing this and i am looking to go this route, i.E cams and other things like porting the head
I personally believe its not necessary but I don't have any data to back that claim up.
If you can find a set of 2.4 cams out of a junkyard send them to Crower for a base circle regrind. Call them up and they'll recommend a grind for your desired build and engine speed.
The bigger throttle body won't hurt, especially because you can tune for it. The intake manifold can be iffy. They technically should be tuned via port length and diameter for your desired powerband and can have negative effects if done incorrectly.
really not needed because a CAI is flowing enough for the head to handle...its not like the CAI isnt supplying enough air
boys and gals, i just found this
https://www.cobaltss.net/forums/jbodyperformance-121/jbp-camshafts-valvetrain-accessories-sale-99742/
well i have a sai intake and i was thinking of concokting somone along the lines of a z06 intake..that splits off two ways..then i thought about it and really how much air can i cram in there kinda thing..
https://www.cobaltss.net/forums/showthread.php?t=99742
I'll try to go as far as I can without vendor bashing, but I haven't seen any before and after dyno results of a "tri-flow" grind. Its staggered intake lobes and on paper looks to me as nothing more than having slightly longer duration with less effective lift than stock. I'd gladly eat my words if I saw a before and after dyno though.
At least one LSJ guy had Crower grind his and WSFrazier spoke with them on the phone last year and they were reasonably priced from what I remember (~250-300 maybe?). I can't remember the turn around time but I'm thinking about 2 weeks.
I'll call Wes and see if I can get him to post some info in this thread.
AND? Seriously tho Cromer and Crane both grind cams for our cars now. In fact Crower does the grinding for the GMPPcams you can buy from GM. When they first came out with them a few years ago I made a bunch of calls (it helped working at a GMPP dealer
) and found Crower does the work for GM. A quick call to Crower and I was talking with a very nice guy who told me they can custom grind any profile I want. GMPP sells the cam blanks and they grind them. I believe Crane does regrinding. Not a fan of the whole regrind idea as I had nothing but problems with regrinds the 2 times I used them in my V8 builds. I prefer useing non regrinds.
