Looking for more power
Just to start off, i know an intake and exhaust will give me maybe 5 hp more, but im looking for something a little more in depth. I was thinking a camshaft, but would that make sense. Im good with my hands, i know i could prollyhandle a task like that, but if i changed the camshaft, would i have to change anything else?
Forced Induction and a Tune.
If you installed cams, you would definitely need a tune as well, and you'd probably want supporting mods (intake, full exhaust, ported/polished heads even?) to make the most of the power gains. Depending on how aggressive you want to get, you may need new valve springs, too.
Intake on the 2.4 is the best bang for the buck - $250 or so for a K&N will get you 10-12 more hp (and lb/ft of torque) at the wheels.
The stock catback on the 2.4 is not that bad but there are gains to be had - more so if the intake is freed up as well.
Toss a header and a decent tune into the mix and 190+ hp to the wheels is possible.
As G85_SS points out, without all of the above plus some porting / polishing on the head, cams will give you nothing - except for a little lumpier idle perhaps.
Cams are far down the list of mods you should be considering.......
Question is why would you want to do anything with valves, springs and injectors? There's no intake manifold or cold air intake going to need better valve springs or bigger injectors. Bigger injectors are for forced induction.
While i dont think the cams are a worth while mod in the beginning I know theres some power to be had there. Not saying huge gains but theres definitely some power to be had.
Im in the same boat though. Starting to modify the car.
From what ive been told header,downpipe,catback,cold air intake and tune.
The ones im most curious about are downpipe and and LSJ throttle body upgrade.
The best mods for the 2.4 are as follows intake, header and down pipe, 2.5 inch exhaust, and tune. With those mods you'll get about 185-190 whp easily. Cams in my opinion are too expensive for the little power gain they give plus like otheres have said you need a tune plus larger valve springs. There more hassle then there worth. Your other power options are supercharge or turbo which will give your 2.4 huge amount of power.
From what I've read on here and other sites, the Trifecta tune is pretty decent if a little longer process.
