lsj head on le5 block
I really don't understand how it will fit but then again I haven't seen his post. I thought there was always a problem because the 2.4's have the VVT. Now with that said I'll do some searching myself and I'll go learn something.
Which I understand that, I wanted to swap the 2.4 for the LSJ for the longest time just because it was polished but then found it you couldn't because of the VVT components not fighting properly.
here are the dyno numbers
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/mvps-official-le5-lsj-2-4-dyno-numbers-100441/
build thread on .net
https://www.cobaltss.net/forums/2-4l-le5-performance-tech-46/official-fullthrottle-build-thread-53093/
and here is the build thread from redline forums
http://www.******************/forums...t=fullthrottle
stop being so lazy and use the search button i found this info in 5 minutes.
Electronic control module and powertrain control module are the same thing, just different names. So other than the pcm what else has to be switched assuming that the vehicle is manual before the swap and u dont have to worry about programming a transmission control computer?
WRONG he used the pcm from his 2.0, there were a couple of things that needed to be changed though for his anyway He wanted to use his exedy stage 3 clutch but the flywheel wouldn't bolt to the le5 block so he had the holes filled and drilled to match. after it was all said and done with the m62 on it and a 3inch pully he put down 265whp and 290ish tq. he had one dyno of over 300 but it did not print and was on a crazy ass tune. So trust me I helped build that motor i know it can be done. this peticular motor was built for a big ass snail shell anyway. a guy on here chevytech007 bought the motor and trans from fullthrottle when he traded in his redline, only paid 1000 for it.
https://www.cobaltss.net/forums/showthread.php?t=100441
https://www.cobaltss.net/forums/showthread.php?t=53093
looks like you were wrong in the tq department. lol
the car put down 262 WHP @ 6,300 RPM and 248 WTQ @ 4055 RPM
He later posts....
we actually pushed the car harder then that and the TQ numbers approached the 300 mark and the WHP was around 280+ but it was knocking bad. so with the 2.5 oully and meth im going back and im going to tune again and run her.
Last edited by ralliartist; Jul 19, 2008 at 05:02 PM. Reason: Automerged Doublepost
He later posts....
He later posts....
kinda like honda's huh lol
Only thing is, Fullthrotle was a LSJ got to a franking LE5 bottom end with the LSJ head. So he was just uping the displacement. For Us we have the LE5 from the get go and have the ECM provisioned for VVT which at this moment we can not just turn off in the tune. Since he never had VVT he did not have to worry about that. We "could" bolt the head on no promblem but the car would freack not being able to phase the cams.
btw, my statement of everything having to be redone includes him having to fix small things such as the flywheel assembly
whatever man all im saying is it can be done and its really not that hard at all. if you have a 2.4 and want to drop and lsj in your car then yeah you would have to have your pcm or computer reprogrammed. I didn't try and make you sound like an idiot...you did that one all on your own.
don't get ass hurt. it sounds like your the nooob. Im not ASSuming anything. So go grab a coke and a smile. there is no need for you to be acting like a A hole.
He actually did a little more than that. not really that big of a problom just find a clean ECM from a ss/sc and your golden.
WRONG. it is my fault i didnt clarify but i think someone got a little ass happy to try and make me sound like an idiot. i was stating that to put a full lsj motor into a standard ss(2.4), or a whole le5 into a ss/sc, then you would have to switch the pcm and what not. so basically, quit being a ******* newb and stop assuming.
why wud u want to put a lsj into the 2.4..kind of pointless if ur not going to boost it..the 2.4 has the better displacement..and really why would u want to do that anyway.....just go buy a 2.0ss/sc with the lsj already in it
on ur face for miles to come
