M62 Supercharger Conversion
Old Nov 5, 2012 | 03:18 PM
06Cobalt2.4's Avatar
So I thought I'd piece together a kit.
Old Nov 5, 2012 | 05:16 PM
Old Nov 5, 2012 | 06:59 PM
noorj's Avatar
Seriously, please stop making repeating/useless threads.
Old Nov 5, 2012 | 07:22 PM
BankerBalt's Avatar
If you don't know what you need and don't know how to search for what you need, then you probably shouldnt be doing a build like this... Also, get bigger injectors than 40's.
Old Nov 5, 2012 | 07:24 PM
royce777's Avatar
for people who cant piece a kit together, ZZP makes a complete kit. they take away the hassle. I would suggest this very much
Old Nov 5, 2012 | 07:47 PM
I copied the list from ZZP's site.. Noor if you have such a problem with me, why do you constantly post on my threads? And I'm not sure how this is useless if I'm looking for information.
Old Nov 5, 2012 | 09:37 PM
chevygirl2006's Avatar
Old Nov 5, 2012 | 10:39 PM
felixrouaud's Avatar
That is hilarious
Old Nov 6, 2012 | 10:23 AM
noorj's Avatar
Originally Posted by 06Cobalt2.4
and I can't recall if there's a thread on here.. I searched a little and couldn't find it again.
Any amount of searching would have found this:
https://www.cobaltss.net/forums/2-2l...thread-208355/
You really need to stop cluttering this section up, like I said, when good information does actually come useless threads like this make it much more difficult to find. You just has easily could have asked the question in your other thread.
Old Nov 9, 2012 | 12:23 PM
klotzy_550's Avatar
Always could have looked in performance mods under forced induction.
Old Nov 9, 2012 | 12:56 PM
Any amount of searching like looking at your link would've noted that it's for the L61 2.2 build, whereas I have the 2.4 LE5. Anyway, I found Beck's guide . Thanks anyway.
https://www.cobaltss.net/forums/how-...through-80620/
I saw someone else note their cost was about $1,300. My goal would be to do this under $1,000.
Old Nov 9, 2012 | 03:33 PM
WickedSS2005's Avatar
I have an M62 for sale, rebuilt blower with upgraded coupler. Looking for $200, pm me if interested.
Tom
Old Nov 9, 2012 | 05:46 PM
nhanson's Avatar
Youre goal is unrealistic. Hard truth.
Just research the many build lists that are posted on here. Mine is even on here. I can help if needed, just PM me.
Old Nov 9, 2012 | 07:38 PM
noorj's Avatar
The LAP is identical to the LE5 except for displacement. The L61 is very similar and if you think you can do it yourself you should be able to figure out how to from any 2.2 guide.
Old Nov 9, 2012 | 10:25 PM
hhrfreek's Avatar
Question.. Am I right if I assume the M62 supercharger is the blower?
Just glue a few straws together from McDonalds, connect them to your intake, drill a hole through your dash and run your straws into the cabin. This will allow you to be the blower.
Asinine answer right?
Old Nov 10, 2012 | 07:48 PM
HHR Panel Man's Avatar
OMFG!
Old Nov 11, 2012 | 06:43 PM
zzCobaltSSzz's Avatar
Lightbulb Supercharged Conversion?
I have a 2007 cobalt SS/NA and i have been looking for a parts list and did not know if this thread would be the same since the thread is for an 06 and mine is a 2.4l ecotec. Ive found an 06 ss/sc at the junkyard. I would like to just build the stock SC system into my car. Im not trying to make a 10 second car i just want alittle more ass to my car and im not a huge fan of turbo's which im sure ill get a bunch of **** for that which is fine but if someone could give me a list of every component i need to rip out of this thing. Thanks guys
Old Nov 11, 2012 | 06:59 PM
Follow this link already posted here and start Reading.
Your junkyard find should work. Also watch the classifieds, lot of SC parts go up for sale on here.
I am just about to start my SC Build on my 08 HHR Panel 2.4 auto trans.
2008 2LT Chevy HHR Panel LE5 2.4 Ecotec VVT Motor Auto Trans
M62 SC
ZZP Modular 3.1 pully
LSJ throttle body
Spark Plugs are NGK 3672(LFR6A-11)
Bad Mab Stainless Steel Header Shorty Header 1.75 primaries to 3" collector
ZZP 3 inch to 2.5 inch high flo catted stainless steel downpipe
All pullies swapped out to the stock 2.0 6 rib pullies
Ebay - CXRacing Heat Exchanger
ZZP Siemans 60# EV6 Injectors
OEM 2.5? exhaust system except replaced the muffler with a Thrush
Spare Cylinder Head has been ported on exhaust side, ZZP LE5 2.4 Cams, 78# Springs, Retainers, ARP Ecotec head stud kit for it. (Swapping out my stock head for the built cammed head)
Glow Shift 30 PSI Boost Gauge
Glow Shift Digital Wideband Air/Fuel Gauge
Stock OEM 2.5 MAP Sensor (that was on the 2.0 intake manifold of the donor cobalt ss/sc)
ZZP Dual Pass
Cobalt Coolant Tank for Option B setup
HPTuners Pro Suite
Spanky's Monkey
Mar 7, 2016 06:06 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
