Meth set up
Old Mar 23, 2010 | 06:15 PM
mmcgee123's Avatar
Meth set up
Since were having knock issues cus I can only get 91 octane in AZ I'm gonna get a meth set up my questions are if I run a 50/50 set up do I need to retune for the meth set up or is it like putting race fuel in and the injectors with scale them self with more air
Old Mar 24, 2010 | 12:12 AM
SSfamilywagon's Avatar
Vince will need to retune you because you will be able to up the boost and hopefully some timing as well.
Old Mar 24, 2010 | 12:31 AM
_UnLiMiTeD_'s Avatar
you need to tune for it
Old Mar 24, 2010 | 02:47 AM
mmcgee123's Avatar
Aight sweet were still messing with the tune right now he's contacting zzp about what. They did with the cam phasing
Old Mar 24, 2010 | 08:15 AM
oldskool's Avatar
Let me just qualify what everyone else is saying - you need to retune to realize the full benefit of the water/methanol injection. That is, if you want to increase boost and/or timing advance.
If you are getting KR because of bad/low octane gas, you can install the water/meth and watch teh KR go away without retuning - you don't have to retune for the octane increase/benefit. You may notice your AFR get slightly richer but the car will generally run better because of consistently low charge temps and increased octane.
Just make sure you choose a nozzle size appropriate for your power output and desired mixture (50/50 from what you said). 5gph or so should really help you out.
Old Mar 24, 2010 | 10:26 AM
mmcgee123's Avatar
K sweet does ne one kno where to get a throttle body space with a port for a meth nozzle
Old Mar 24, 2010 | 10:31 AM
MP Cobalt's Avatar
ottp has then for like 40 bills
Old Mar 24, 2010 | 10:40 AM
Durtyss's Avatar
Ya ottp and zzp have the spacer.I'm going to run 50/50 just for cooling effects. Also I have a ? How did everyone run there lines from trunk to engine bay for the meth line.
Old Mar 24, 2010 | 10:41 AM
MP Cobalt's Avatar
I have mine under the floor panel like how you tuck speak wires. The lines are pretty stiff like hard to squish so I figured they'd be fine under there
Old Mar 24, 2010 | 12:19 PM
Durtyss's Avatar
Were do u come thru firewall at?
Old Mar 24, 2010 | 12:33 PM
MP Cobalt's Avatar
Behind the pedal you'll see a little circle rubber plug thing I took it out grabbed a screw driver and poked a hole thought the plastic/rubberize stuff and ran it through there.
Old Mar 25, 2010 | 07:30 PM
glen229's Avatar
i just hooked my meth up sunday, just gotta up the boost and plug it in
Jan 12, 2016 12:01 AM
OrangeCoba
Oct 1, 2015 10:00 PM
yellow dragon
Sep 28, 2015 09:49 PM
Sep 27, 2015 08:53 PM
