motor cutting out in 2nd gear!! Any ideas
hi guys new to the forum, whats up. I installed a Tusudo catback exhaust and injen intake on my 07 SS non S/C. Everything else is bone stock. When floored in 2nd the motor cuts out for a split second its just annoying im not worried about this problem but was wondering if theres a cure. Im pretty sure its due to the intake not to sure i installed both at once without driving it first. Thanks in advance. (There is a CEL on code p1072 rich fuel ratio) not worried about the light either but is there a was to shut it off
yea for a split second. between 3500 and 5 grand. i know the whole motors cuting out because the exhaust is quiet for a second.
mine cut out at 2.5 to 3.2 i dont push it that high often. any ideas on what it could be?
but it only did it once. did urs start slow and then get worse?
no its been doing it the same for the past 2 months dosent seem to be getting any worse. my only idea is the computer is shutting off the fuel for some reason due to the extra air coming in from the intake but that dosent make sence it seems like it would be wantin more fuel to compensate
hmmm??? and it doesnt throw any kinda code? maybe check your mass air flow sensor. Is it due for any kinda tune up? spark plugs, fuel filter maybe. How many miles do you have on yours?
I have had mine do that a few times, found immediately when I looked down at my DIC it showed the "traction" message...
dunno if that has happened to anyone, or this helps you at all
ok it just did it again yesterday except it did it a bit wors and alo in third and it only happens when im really pushing the gas pedal. and then i parked somewhere for like 5 minutes and left again and it stopped.
2.4 issue
real sorry to thread jack guys but this thing wont let me post my own and im pretty new so dont know wats goin on but i have a 2.4 took the head off and stuff (long story) but if anyone knows how to retime these things and could give me some tips i would owe you a kidney thanks!!
