need some help???
Old Feb 21, 2008 | 03:33 PM
Vetteman99's Avatar
need some help???
for those who got the B&M shihft plus where did you mount the switch
Old Feb 22, 2008 | 12:36 AM
Viper33884's Avatar
I mouted mine like just to the right of where your right knee would go on the plastic with some double sided tape. Nice spot to have it and wiring runs right to the conter consol never showing. Need any pics for better discription.
Old Feb 22, 2008 | 12:44 AM
lil_kano's Avatar
I put in the little pull down box for the trunk pop. A little double sided tape on the side makes for a clean look.
Old Feb 22, 2008 | 12:48 AM
Viper33884's Avatar
Also make sure you clean the hell out of the switch itself, the coating around it doesn't like to stick that much, I used some regular rubbing alcohol.
Old Feb 22, 2008 | 04:41 PM
Vetteman99's Avatar
can i get some pics for a discription
Old Feb 24, 2008 | 11:24 AM
Viper33884's Avatar
I got your PM and also just read this so now I know what your talking about, I will try to get a few pics in about an hour.
Old Feb 24, 2008 | 03:01 PM
cobaltcruisin's Avatar
Under the steering wheel.
Use the lever to tilt the wheel up. Place the switch in the gap that is created by the dash panels and steering wheel, then use the tilt to push the wheel against that switch tightly.
Waala.... no modification necessary. Its out of view from everyone other then you and its easy to run wires. Sorry I dont have pics as I removed mine.
Old Feb 26, 2008 | 11:18 AM
Viper33884's Avatar
Never thought of putting it there, and I'm waiting for my pic to be sent to my e-mail from my phone, damn thing takes forever.
Old Feb 26, 2008 | 03:01 PM
Vetteman99's Avatar
thanks for the help
