Philips Xenon HID's, Jet Performance Modules
Old Jul 5, 2010 | 09:47 PM
trentonwayne's Avatar
I'm in the process of installing Philips Xenon HID headlights and Jet Performance Modules. Will keep you updated on power increase, acceleration and fuel economy. As well as headlight operation. Will not be providing a Dyno. Just my opinion.
Old Jul 7, 2010 | 05:42 PM
Update.
Got my headlights in, a lot of troubleshooting was required, but this was because of a faulty relay. Which makes switching from dims to brights unreliable. Shipping new relay now, should have it in a few days. Dims are 10x brighter than my dims on my stock headlights. With the new relay, i will have both dims and brights. It was simple to install, but, a pain going through the troubleshooting. An amateur can do it with patients and time. Philips customer service was outstanding and very helpful.
Will keep you all updated.
Old Aug 12, 2010 | 10:27 PM
Update
So I have both the lights installed and he jet performance modules installed. Here is are links so you can know what I actually installed.
http://www.summitracing.com/parts/JET-68021/
http://www.summitracing.com/parts/JET-10608S/
http://www.summitracing.com/parts/JET-69143/
http://www.philipsxenon.com/chevrole...philips-p-1245
The lights are bi-xenon. Meaning they have both low and high beams. With the lights I had the biggest problems, spent time with technical support figuring out why my headlight are only on dim. Their technical support is awesome btw. The brights do not work, and still do not work to this day. If anybody else has this problem and knows the solution, let me know please. The dims are as bright as my brights of my stock headlights. So all is not lost, I am used to driving in the early morning and late night and would just like to flash people, I hate when people don't have their headlights on when they clearly need to be. I bought these on black Friday last year in 2009 for $180. I was unable to find time during the winter to install and finally got around to it this year. In waiting I lost the warranty, which is why they couldn't replace anything for free. So after hours on the phone they and I came to a mutual agreement and they gave me a set of free HID fog lights to make up for the bright loss. I'm ok with that for now. The fog lights are the same color balance as the headlights, but they are not Phillips xenon. To conclude with the headlights they are a perfect white light set at 4300k. Easy to see the white line in the rain!! Very bright and easy to install. Dummy proof.
The Jet performance modules were simple to install as well. The easiest was the Powr-Flo Mass Air Sensor http://www.summitracing.com/parts/JET-69143/. The most difficult was the JET V-Force Plus Performance Module http://www.summitracing.com/parts/JET-68021/. The only reason why it was the most difficult is that you had to go threw the firewall. Which is right under the steering wheel and right by the brake pedal. Just make sure you don't cut/splice the wrong wires when connecting. Patients is key when working on anything electrical on a car. For safety reasons always disconnect the battery before doing anything electrical. ..duh.
Power and gas mileage. Greatly increased! Auto shifting also improved. Smoother. The majority of the time I run on e85. Without the improvements listed above I got 26 miles per gallon with e85, 34mpg with premium. Now with all the other improvements listed above I get 32mpg with e85 and 38mpg with premium. Those are averages of daily travel of both a mixture of 25% city travel and 75% highway. When I hit the gas mileage reset button on my dashboard I got 26mpg with e85 before the improvements and now 38mpg with e85 traveling at 55mph. 34mpg before the improvements and 43 after with premium at 55mph. I like to accelerate fast, which is where my gas mileage goes wrong. My opinion. These chips work. If you choose to buy, let me know what you think, if you need any help installing, message me or post here. Thanks for reading!
Old Aug 12, 2010 | 10:30 PM
09sscalicobalt's Avatar
haha i worked at jet performance for 3 years and happy to hear this from a fellow cobalt owner i always told people they were but alot of cobalt owners didnt believe me hows the new vforce plus tho? they came out wth that after i stopped working there
Old Aug 12, 2010 | 10:36 PM
kingg5's Avatar
my 06 2.2. base will not make my bi xenon hid kit switch to high either...pissing me off to no end. works fine on everyone elses...not on mine
Old Aug 12, 2010 | 11:51 PM
mtbrent's Avatar
You are running E85 in a na 2.4?????? And with the Jet stuff????
Old Aug 13, 2010 | 12:58 AM
DFZ24's Avatar
ok i figure that problem out of the hid!!!! i had the problem, no one here could tell me, so i began playing with it and fixed them by doing trial and error lol
but i think they are not fully connected lol because i think my high beam are not going fully down to do the high beam. more like med beams lol
i dont care much at least now i can do and have high/low beam and flash ppl.
i should had made a thread how to fix it lol
i had the same problem, hid turns on, but only in low beam cant use high beam or flash them with your low beams on.
i turn off the lights and use high beam or flash them and the lights will come up (dont know if it is highs or lows)
is this the issue you guys have??????
Old Aug 13, 2010 | 05:26 PM
riko540's Avatar
You didn't know the 2.4 is E85 compatible?
Old Aug 13, 2010 | 05:37 PM
boostedsport's Avatar
thats news to me too thought u had to be tuned for it
Old Aug 13, 2010 | 11:26 PM
mtbrent's Avatar
It most certainly is not in a cobalt. The LE9 (e85 capable version of the LE5) is available in the HHR and Malibu, but not in a cobalt. I was thinking maybe the OP has one of them, but the parts he bought are for an 06 cobalt . THIS is interesting!
Old Aug 14, 2010 | 11:21 PM
DFZ24's Avatar
hey sorry i havent type the solution for the hids if you havent fix them. im trying to get some pics to i can make it easier for you, other than that is super easy, just need patience and trial and error goes with it lol.
Old Aug 14, 2010 | 11:32 PM
CordiaDOHC's Avatar
I had good success with the Jet modules (stage 1 and 2) since the programmer isnt available for 08's.
Old Aug 15, 2010 | 01:00 AM
hmm whyd you buy both and yea no programmer for your car just the vforce plus and maybe the maf sensor
Old Aug 15, 2010 | 01:03 AM
CordiaDOHC's Avatar
Got a good deal on them from a member on here. can honestly say my car was faster with the stage 2 and a cold air intake than it is with a cold air intake catback and a header without the module.
Old Aug 15, 2010 | 01:16 AM
oh yea they for sure work like i said i worked for them for 3 years i know wutsup lol
Old Aug 15, 2010 | 01:18 AM
CordiaDOHC's Avatar
yeah I only sold it so I can go with a full tune so I can get the trans tuned as well since im an auto.
Old Aug 15, 2010 | 01:25 AM
oh ok yea they dont make **** for my car i still gotta get a tune one of these days lol
Old Aug 19, 2010 | 02:10 AM
I would like to know how to fix the HID problem
Old Aug 20, 2010 | 12:47 AM
DFZ24's Avatar
sry man i will write you the solution, right now im in orlando with some family out of country.
basically if you can understand this....
you know the socket where the regular headlights connect to right???
on the HID one is connected and the other is not connected. the one is connected if you look there 3 wires.
by trial and error rearrange the wires till you see the high and low beams works, dont worry if you connected the wrong way because the only thing that will happen is that one of both will work (high or low but not both).
if you have any question just write here ill try to keep checking, also let me know if you fix it.
hope this works if not i will take pic to show you.
Old Sep 7, 2010 | 08:30 PM
lead_foot's Avatar
I need help on this issue. Some more clarity please. I just bought a bi-xenon kit from Notto SE on Carid.com. I'm currently on the replacement kit because they sent me a new one because the other didn't have hi beams. Now this one doesn't either. I can hear the ballasts clicking to change my lights. Do i rearrange just 2 out of 3 wires and leave my ground alone or what?
thanks!
Old Sep 8, 2010 | 01:46 AM
Hey there, DFZ24, thanks for your update. Appreciate it. I tried this before, and nothing helped, i will try it again, and keep you updated. :-)
Old Sep 8, 2010 | 02:00 AM
Cobalt Halogen on the left, my Cobalt HID on the right.
..no editing was done. And both headlights are set on dim.
Old Sep 8, 2010 | 02:54 AM
DFZ24's Avatar
thanks!
at the beginning i rearrange only 2 but didnt work so i ended up rearranging all of them until it worked.
I will see if i make a vid so you guys can see it.
my bi-xenon were given to me as gift, i didnt like 6k so i just bought the bulb (5k to match my fog lights) from ddmtuning i think.
cables were different colors, i try to follow the pattern from the others and didn't work so i ended up, rearranging all.
Old Sep 8, 2010 | 03:02 AM
DFZ24's Avatar
this is the one that i rearranged.
by trial and error i got it working
Old Sep 11, 2010 | 03:20 AM
Got it! Thanks buddy, really appreciated it :-)
