pure curiosity
Old Jan 7, 2009 | 01:01 PM
mike25's Avatar
Harrop TVS Possibilities
ive been thinking for the past couple days about even going supercharged and i was wondering...in theory what could the 2.4l le5 motor(stock) accomplish with a harrop blower?
Old Jan 7, 2009 | 01:10 PM
Jackalope's Avatar
It all depends on what you define "stock" as. Also how much boost?
But I think its only good for 300 and something before it blows its rods.
Old Jan 7, 2009 | 01:11 PM
brickerenator's Avatar
Only one way to find out.....
You might try looking at the Solstice 2.4 builds to see what has been done
_UnLiMiTeD_'s Avatar
depends on how much boost u run. i know the 2.4 on the stock blower off the 2.0 would make over 200 whp on just 8 psi, thats everything stock.
D4u2s0t's Avatar
a stock 2.4 with a harrop on it would go boom. wouldn't expect much of anything.
Old Jan 7, 2009 | 01:25 PM
elecblue06's Avatar
wow the only person that posted something worthwhile lol
how much would it take on the harrop no idea..
it makes about 240 whp on 8-10 psi with the m62...
and then there are solstices running stock engine at well above 300 whp...
i think it would be very interesting to drop the tvs into a 2.4 ... i think it would produce some nice numbers
Old Jan 7, 2009 | 01:29 PM
mike25's Avatar
just an idea..not sure of anything technical
Old Jan 7, 2009 | 01:49 PM
celicacobalt's Avatar
i think the 2.4 with a good tune should be able to put down 400whp on stock motor
Old Jan 7, 2009 | 02:01 PM
mike25's Avatar
your refering to the harrop?
Old Jan 7, 2009 | 02:05 PM
haha
that would be a craaaaazy tune if he wasn't
Old Jan 7, 2009 | 02:09 PM
elecblue06's Avatar
in general.. i think the harrop will be a bit less though do to parasitic loss but it should still pump out some numbers
Old Jan 7, 2009 | 02:11 PM
as compared to....the M62?
mike25's Avatar
how bout this....close to or right at 300hp reliably on a stock motor...and then close to 400 built with a better tune...achievable?
Old Jan 7, 2009 | 02:19 PM
elecblue06's Avatar
i was talking about gettin 400 whp on a turbo being possible but harrop/ m62 will result in less because of parasitic loss.. m62 even more because of heatsoak..
sorry i didn't really explain..
also i'm not sure how our fuel system is .. if it'll **** the bed on a roots style sc at high boost and starving cyl 4.. like on the lsj's the only 400 hp 2.4's i've seen / heard of are turboed
Old Jan 7, 2009 | 03:12 PM
Dunkinuts's Avatar
in all honesty I think the LE5 will handle nitrous better then boost.
Old Jan 7, 2009 | 03:32 PM
elecblue06's Avatar
actually quite the opposite depending on the form of boost.. nitrous is a sudden shock to the system.. gm popped the 2.4 at like 250-300 hp using nitrous.. and popped the lsj at about 350 using nitrous ..
is a sudden stress on the engine.. which is mor elike a roots SC something that eases into it more like a centri SC or a turbo will be easier on the engine
Old Jan 7, 2009 | 03:44 PM
Dunkinuts's Avatar
progressive controller and stages.
Old Jan 7, 2009 | 03:50 PM
elecblue06's Avatar
true you could do that but then you'll have a really expensive setup
Old Jan 7, 2009 | 04:52 PM
mike25's Avatar
point is this thread wasnt made conscerning nitrous....
Old Jan 7, 2009 | 09:05 PM
tsunam1's Avatar
I HAVE NO IDEA WHAT I AM TALKING ABOUT....BUT...the TVS just sounds like a more expensive option when you could go m62 and use a smaller pulley instead of the stocker. More air is more air, has anyone with a sc 2.4 tried that, or is that totally ridiculous?
Old Jan 7, 2009 | 10:12 PM
pjk91's Avatar
340whp on the big pulley they send with it. 380+ with the small pulley.
Old Jan 7, 2009 | 10:36 PM
mike25's Avatar
how would that do on a stock motor? bad or ok if tuned right?
also take for instance i go and put in forged rods/pistons, possibly the same compression, or a BIT lower(9.5 at most)...how would that do? alot more reliable?
Old Jan 7, 2009 | 11:04 PM
lsjwannabe's Avatar
Not happening.
To the op, i would be a little more concerned with the trans as i know the s/c 2.4 guys were having a couple problems keeping them together.
Old Jan 7, 2009 | 11:11 PM
mike25's Avatar
Originally Posted by lsjwannabe
Not happening.
hhmm now that you say something i seem to remember that....i guess in short it just really isnt possible to run a supercharger to extensive...thanks for the info...back to turbo i guess..lol
Old Jan 7, 2009 | 11:13 PM
lsjwannabe's Avatar
How is the m62 for fitment on the 2.4l? Mainly clearance of the fuel rail.
