Question about Hahn's turbo kit
Old 09-27-2007, 01:52 AM
firebalt's Avatar
it says on tntautosports that you are required to send in your ecm for a reflash prior to installation?
to those who have it installed, how's the installation?
Old 09-27-2007, 08:04 AM
celicacobalt's Avatar
install is supposed to be fairly easy, had mine installed though... but yeah you have to mail your pcm and tcm to hahn for the tune.
Old 09-27-2007, 09:48 AM
iLLmaTic3s's Avatar
yeah that sucks..the only thing which kinda sucks...is hahn locks ur ecu..so u cant do any further tuning thru HPtuners as what I'm using...kinda blows.
Old 09-27-2007, 10:20 AM
you can tune thru the fpr though so the end tuning is adjustable and hahn can set your timing accordingly to what you want. end user tuning works fine though.
Old 09-27-2007, 10:28 AM
iLLmaTic3s's Avatar
yeah i dunno im giong back and forth between s/c and turbo...and tuning.
Old 09-27-2007, 10:44 AM
WunSick's Avatar
is this a software lock ? i betcha they just cut some leads or something to prevent flashing, got any pictures of the ecu board ? just intrested....
Old 09-27-2007, 11:04 AM
LewiSS's Avatar
The only systme on the board that appears to truely work with no drivability or CEL issues (so far) is Celicacobalt's car. The Alpine kit on my car never worked (tune-wise), and if you go S/C you're on your own - there is no turnkey solution. The ECU in the 2.4 is too sophisticated to simply bluff it into accepting a S/C or turbo the way all previous kits for EFI cars did it. Take it from someone who lost a bunch of money trying - if there's a proven, drivable solution with no CAIs, spend whatever it takes to get it. So far, that means Hahn, and only Hahn. ANY attempt to low-ball a solution WON'T WORK.
Old 09-27-2007, 04:39 PM
iLLmaTic3s's Avatar
totally understandable man...in time the tuning will come.
Old 09-27-2007, 05:46 PM
RDKDESIGNSG5's Avatar
I also have the Garrett kit. I didnt go though Hahn on the changes they made for the kit. But I do have the Hahn Tuning setup. My car runs great with no CEL or anything..
Ryan
Old 09-28-2007, 01:26 AM
firebalt's Avatar
hmmm hahn's shop is in IL
maybe they could do it in a day in shop haha
(live in IL btw)
ineedacobaltss
11-07-2015 02:25 PM
brandon04
10-21-2015 07:04 AM
CobaltSS 16
09-29-2015 01:53 PM
09-27-2015 08:53 PM
09-26-2015 06:44 PM
Quick Reply: Question about Hahn's turbo kit
