Question Time!!
Old Sep 12, 2006 | 04:51 PM
jrcobaltss's Avatar
Question Time!!
Okay well i have the Pursuit G5/Gt and i have been talking to my dealership about getting the GMPP Performance Exhaust.. Well he got numbers for me today and it is going to cost roughly 645.xx$ Canadian for Full Install and Thats Including Gst...dont forget this is in Canadian Money.. so its a bit more expensive... im deciding if i should go for that.. or purchase the exhaust off a website and have them install it for 2 hours at 95$ an hour.... can i please have some opinions?
Regards,
Andrew
Old Sep 12, 2006 | 04:54 PM
Doc's Avatar
Doc
Install it yourself. Seriously, you could buy handsaw and a jack and jack stands for less than that. You'll need hand tools for the bolts.
Also, how far are you from the border..??
wait, the exhaust and install is $645..?? Hell, it runs a little over $400 for the exhaust here, not sure what the exchange rate is though.
Old Sep 12, 2006 | 04:56 PM
g5mike's Avatar
I paid 200 hundred less from my dealer,Do not buy from them, use one of the forum vendors, some guys are payind 325.00 for theirs
Old Sep 12, 2006 | 04:57 PM
g5mike's Avatar
exchange rate is .9 on the dollar
Old Sep 12, 2006 | 05:00 PM
Doc's Avatar
Doc
thanks, buy it elsewhere like g5mike suggested and put it on yourself. Seriously, it is easier than you think.
Old Sep 12, 2006 | 05:03 PM
g5mike's Avatar
It took me 25mins to put mine on
Old Sep 12, 2006 | 05:05 PM
D4u2s0t's Avatar
it took me 45 minutes to take my old exhaust off, and put the new one on.. and i have never done an exhaust before, ever... if someone tells you it's 2 hours, they're ripping you off big time... you can very easily do it yourself with little to no experience... you literally take off 2 bolts that connect to the cat, remove the rubber hangers, and that's it... may have to cut the pipe to get it off... to put the new one on, you just bolt it back to the cat, put the hangers back on, good to go
Old Sep 12, 2006 | 05:12 PM
g5mike's Avatar
Holy ****,I did not see him post 2 hours. Dude do not take your car to that stealership for anything
Old Sep 12, 2006 | 05:14 PM
jrcobaltss's Avatar
Gah.... i cant do it myself.. because my parents are all crazy about warranty.. and i will need to get it done through the dealer.. just 645$.. i dunno its kinda expensive..
D4u2s0t's Avatar
yea... mine would have been done a lot faster too, but i didn't have a very good saw to cut off the old exhaust, that's what took the longes out of everything... with a good saw it would have been probably half the time...
Old Sep 12, 2006 | 05:15 PM
D4u2s0t's Avatar
your warrenty will not be affected either way if you do it or if hte dealer does... has nothing to do with it...
Old Sep 12, 2006 | 05:16 PM
jrcobaltss's Avatar
My dealer said.. it wouldnt be covered if say. i did it myself.
Old Sep 12, 2006 | 05:17 PM
D4u2s0t's Avatar
that's because they want to overcharge you and take your money... they cannot void your warrenty because you installed an exhaust, trust me... that's the first rule to know when you start modding...
Old Sep 12, 2006 | 05:26 PM
jrcobaltss's Avatar
try telling my parents that frikk... so is there no welding involved?
Old Sep 12, 2006 | 05:31 PM
D4u2s0t's Avatar
there's no welding at all... it's 2 bolts, and rubber hangers... that's it..
Old Sep 12, 2006 | 05:32 PM
D4u2s0t's Avatar
look up magnason moss and show it to them... it basically says that it's illegal for your warrenty to be voided from using aftermarket parts... they cannot void your warrenty because you installed an exhaust, unless it was installed wrong and that's what messed things up.... but trust me, you're 10 year old brother can help with this install...
Old Sep 12, 2006 | 05:39 PM
jrcobaltss's Avatar
Alright, thanks for all the support. and i may have my dad convinced saying " This is my first car, i want to learn about it, i pay for it so i want to have some part in the mods i am going to be doing on it. Umm if its not a big pain in the butt.. how many jacks will i need...you said i might have to cut the exhaust.. am i cutting the old one or the new one? and is there instructions that come with the exhaust when you buy it?
Thanks,
Andrew
Old Sep 12, 2006 | 05:43 PM
g5mike's Avatar
Thanks,
Andrew
Just drive it some where and put it on and tell him the dealer did it,my dealer told me to do it myself or take it to some muffler shop,and yes they still warrenty the product.Dont forget some dealers have much more knowledge than others
Old Sep 12, 2006 | 05:47 PM
jrcobaltss's Avatar
Cool.. i think me and my dad should have no problems installing it ourselves.. my dad has some background knowledge on cars.. and he has a ton of knowledge on Trains.. because he works for Canadian Pacific Railway... so cars are just on a smaller scale.. hahaha i think i might order it and do it myself then. Thanks
Old Sep 12, 2006 | 07:04 PM
jrcobaltss's Avatar
Oh yah if anyone could answer this question...... If i do buy the Gmmp Performance exhaust... how do u put on the tip that you need to buy seperate? Im kinda confused on thsi part.. Thanks
Andrew
Old Sep 12, 2006 | 07:11 PM
mkulrey13's Avatar
the exhaut dossent come with a tip, you either have to order the stright or slanted tip.
Old Sep 12, 2006 | 07:15 PM
jrcobaltss's Avatar
Yeah, so when i buy the tip also. how do i attach it? does it have a clamp or.....
Old Sep 12, 2006 | 07:16 PM
D4u2s0t's Avatar
you will need jacks for the back mostly... in the front of the car (towards the middle actually) there are 2 bolts... if you look under the car, and follow the exhaust pipe back, you'll see what i mean... i used 2 ramps for the back of the car and had no problem... not sure about the tip...
as far as cutting, the old exhaust will have to be cut off, you'll see where when you have to cut it... it won't come out because it won't bend over the axle... you'll see what i mena..
D4u2s0t's Avatar
mine came with a clamp, but i don't have the gmpp so i'm not sure about that...
roccobladr's Avatar
can u use ur old tip? say if u have a 2.4 ss?
