seafoaming 2.4
wher eyou been vpec?
idk how the 2.4s look but i just found a vacuum line and pulled it off to do it on mine.
1/3 in gastank, 1/3 in oil, rest in vac line.
let it sit for 15 mins, run it, then drive for idk 10 miles (After it stops smoking like method man and redman) then CHANGE THE OIL. can't stress that enough.
but any vaccum line eh?? idk.. i jsut wnt liek a oog how to for the 2.4's havent seen one around for it..
ok thats what i thought it was... now shoudl i use a differnt piece of hose.. or disconnet it from the brake thing.. and use that?
its hard to explain, but there is a really thick hose that runs from the throttle body, to the right and then back under the fuse box to the firewall. it attaches to the master cylinder (big circle thingy) and just pull it out and suck it through there
Should be easy to do. Find the vacuum line and dump 1/3 of it into there. Should come off of the intake manifold near the throttle body. When you take off the line while the car is running it's fairly obvious as to what it is.
yeah can someone P.L.E.A.S.E!!! post a pic of the line to use!!! I cant find a pic of a spot on the Le5 to seafoam save my life
and I've heard that it can damage cars with a few miles on the engines cuz it can break up the trash thats holding the gaskets in place... is this true?
I do recommend that you change oil in less than 100 miles when adding to oil though.
1. it thins out the oil
2. it can get dirtier
