Service engine light on P0300, P1174
Old Apr 16, 2010 | 04:48 PM
murphy_5's Avatar
Hey guys I work at a local repair shop in Waterloo, Il I have a diagnostics tech telling me I need to replace all 4 of my injectors & reprogram due to a TSB I have 2 of the 3 engine codes on and we can watch cyl. 4 misfire lots on idle approx. 1000 times in a 5 min span. so we ran the injector balance check and all came up ok. What do you guys think about this? I don't feel like dropping 300 bucks on a guess HELP!
Old Apr 16, 2010 | 04:53 PM
elecblue06's Avatar
misfire sounds like a coilpack
Old Apr 16, 2010 | 04:57 PM
murphy_5's Avatar
one is a random misfire code P0300 and the other P1174 is Fuel trim cyl. Balance B1
Old Apr 16, 2010 | 05:04 PM
elecblue06's Avatar
sounds like an out of wack tune then
murphy_5's Avatar
I'm going to move the #4 coil to the #1 coil and check that to make sure its not a coil
Old Apr 17, 2010 | 08:09 AM
mmcgee123's Avatar
Check for vacum leaks
Old Apr 17, 2010 | 08:13 PM
murphy_5's Avatar
Well I switched the coils over and still the same so I took the plugs out and check them and switched them and still the same...I'm running out of options looks like my tech is getting his guess right so far
Old Jun 15, 2010 | 10:12 PM
snowman65's Avatar
fix
If your p300 code is indicating which cylinder is misfiring, change the coordinating fuel injector. I had both these codes on mine, with a p301, I changed the cylinder 1 fuel injector and no more problems.
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 04:49 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
grampss
Sep 27, 2015 08:51 PM
