Sri Or Cai
Doesn't make a difference honestly. An intake is an intake...they all do the same thing and serve the same purpose. The whole "short ram" and "cold air" thing are all gimmicky descriptions. The only difference between a "cold air" is that the filter is located outside of the engine bay...performance wise it's just going to take slightly longer for air to pass through the longer tube, but that's it. It's miniscule stuff.
Just find what's the cheapest and what fits properly and get it.
Go with the Injen intake for our cars. As far as I know, it's basically a SRI with the extension crap needed to make it a CAI as well so you can have it either way. Someone please correct me if I'm wrong.
Originally Posted by BlackWinterDay
Good advice right there.
Yes, basically all "cold air style" intakes are just longer piping or piping with some type of coupler to connect the piping together to lead outside of the engine bay and have the filter located outside of the engine bay. This all depends on the company.
So yeah, it may be a smaller difference between SRI and CAI.... but it's not the same thing. There is a difference. You should do the CAI setup unless you live in an area where you might submerge the filter in the fender (ie. lots of flooding in your area... big ass puddles that you can't miss).
in my opinion it doesnt matter even though you are getting colder air its still passing through the hot engine bay. it could make a difference if you are not running your car for long periods like a single run let it cool down and then run again. but like my man NJHK said it doesnt matter.
Originally Posted by ppazz1101
They are different. CAI setup brings in cold air from outside the vehicle's engine compartment. SRI brings in hot air.
The fact is that when your car is in motion, there is enough cool air circulating inside your engine bay. If there wasn't, your engine temps would more than likely be higher being that the engines heat wouldn't be escaping the engine bay.
As far as your claim of "cold air on the outside", the temperature on the outside determines how cold your air is whether if the filter is on the inside or outside. Ever drive a stock car during a hot day and during a cool night? Notice a difference? Of course. Proves right there that cool air makes it inside your engine bay and inside your intake system. It's the same temperature as the outside.
Companies that make "cold air style" intakes want you to think that the heat generated by your motor just goes right back into your intake system and is somehow decreasing your performance over their all might and wonderful CAI style intake. IT'S A GIMMICK!
If you're N/A an engine temps are climbing extremely high, there is more than likely something wrong with your cooling system...not your intake.
Originally Posted by OrangeCobaltSS06
I tested this last night at the drag strip. I ran 16.2 w/ the CAI and a 16.7 w/ the SRI(Tucson is at 3400 ft. so you run alot slower then you should) the SRI killed me in the mid-range.
Let's see a dyno of a bone stock 2.4, the same 2.4 with an Injen SRI, and then again with the SRI extended to a CAI. Until someone goes to all that trouble, I'm not buying it.
And as for engine temperature... your engine temp is based upon your coolant. Your coolant is cooled through your radiator which sits right behind your front grill so that it can be cooled by the moving cooler air from outside of the engine bay. No offense... but you're a fool if you think the air under the hood of your car is the same temperature as the air from outside. Sure, you may get a little bit of circulation... but not much.
go SRI
people may complain saying that CAI is better because it brings in "cold air", however, when the air travels up the longer METAL piping tube, the air's temperature increases because the METAL piping (which is next to the hot engine), becomes just as hot!
Originally Posted by savior
go SRI
Originally Posted by PpAzZ1101
Ever look at the stock intake on a cobalt???? The stock intake runs into the fenderwell area. It sits in the same area as the CAI filter sits. So driving a stock car on a cool night will feel different than a hot day because your stock intake is bringing in air from outside of the engine bay. You only proved my point there.
My question to you is how do you know how hot it is under your hood while in motion?
Also, there are other stock cars besides the cobalt and their intake system lies inside the engine bay and doesn't look for specific air from the outside.
i got the cai either or is good i guess other then an sri u would be just suckin in warm air sence its by the motor but i dont like the whole dangling there thingy without a bracket for the sri so thats my main reason for just completing it lol..
Run an SRI setup. Take a good drive to get your engine temp up. Pull over, turn off the engine and immediately check the SRI tube. It's very hot to the touch.
Then run the CAI setup. Take the same good drive to get the engine temp up. Pull over, turn off the engine and immediately check the portion of the tube that's on for SRI setup (this pertains to the Injen intake since you can convert it). It's cool to the touch. It'll warm up after you let it sit there because of the heat under the hood and no cool air flowing through the tube. But if you check it right after you pull over and turn your engine off, you'll see how cool it actually is.
I already explained...
Whatever...I'm tired of arguing something as pointless as intakes. It gives you mediocre gains no matter what style you get.
I've always had an "short ram" intake and I can honestly tell you that it's never been so hot that I can't touch it. Even my charge pipes which contain even warmer compressed air, I can touch them no problem.
I'm tired of arguing over it too. Bottom line is either SRI or CAI setups will give you a small gain over stock. There's very little difference betwen SRI and CAI... but CAI is slightly better (in the opinion of some).
Friends?
I agree with PpAzZ1101
I've ran both and while gains from just an intake period are small...the CAI is just slightly better. Most people are fooled into thinking the SRI is better because of the throttle response but its not
I said it was very hot to the touch. Not too hot to touch.
Friends?
Friends?
Truce.
