SS 2.4 ecu same as corvette ecu?
all laughter aside I think they have the same software with different variables (obviously) so once one is broken the other will be as well .. WopOnTour was saying something about it iirc and he is a very reliable source.
Hope this clears it up for the people still giggling
https://www.cobaltss.net/forums/show...37&postcount=5
Originally Posted by WopOnTour
AFAIK both the 2.4 LE5 and the Z06s 7.0 litre LS7 utilize the "new generation" E67 ECM, (3900 V6 and 4.6 supercharged as well)
Originally Posted by red_wing_2121
Think about it man: Corvette - V8, Cobalt - L4.
There is no way they could have the same ECU.
I do not believe that the Vette and Cobalt are using the same engine controller. HOWEVER - those of you that called the guy stupid for even suggesting it are pretty wrong. GM's new family of engine controllers is very flexible and can be used for many things. The same controller is being used out there already for 4cyls, V6s and V8s. Same hardware, different programming obviously. Obviously you couldn't just take a Vette controller and plug it right into a Cobalt and go, but if you could change the software, the hardware would be quite compatible (which was his question, I believe).
Actually YES
The 2.4 Cobalt and the LS7 Vette both use E67 boxes SO THE HARDWARE ITSELF IS IDENTICAL (the SS/SC uses a P12 PCMs shared with the Colorado and Canyon trucks)
In fact if you look and compare their wiring schmatics they have a LOT in common...
However as Dan mentions the flexiblity of the latest 32-bit control units means they can be setup to function differently in different platforms and powertrains
WopOnTour
WopOnTour
Uhmmm NO the LS7 uses an E38, and the other new LSX series use an E40/E38.. The Cobalt uses an E67 WHICH IS NOT COMPATIBLE WITH THE OTHER CONTROLLERS! How on earth are you getting they are the same ECM?!!? Hell anyone off the street could see the E38 for the LS7 has TWO connectors and the E67 for the 2.4L (and others) has THREE LOL
Originally Posted by DanM
Point is most of these things are at least somewhat cross-compatible
Originally Posted by celicacobalt
If this is true then does that mean if a piggyback ecu is made for the corvette that the 2.4 ss can use it as well for tuning?
Originally Posted by GTPprix
Yes and no really.. The OS's are completely different, calibration segments of course and the outputs are of course different. I'll have to pop open one of the E38's I have here but I'm 99% sure from what I remember that the Microcontroller isnt even the same although they both have 2MB of flash now..
