ss injectors?
only time you really want to get bigger injectors is if they're close to maxxed out, or if they ARE maxxed out. other than that, no real reason or benefit to get them.
see, an injector has a range at which it works well, so, generally, they start getting close to their limit at upper RPMs. so, if you are often near the redline, it can't hurt to do it.
well, you'll have to pay to have the car tuned. that's the expense.
Last edited by joeworkstoohard; Jul 23, 2008 at 03:37 PM. Reason: Automerged Doublepost
this is true.. i want to see if anybody local to me has a tuner.. and ill pay them for the use instead of me buying one which is upwards of 500 dollars or brining it to someone just for an injector tune
what are you looking to get out of this? and what are your future plans for the car?
stock 2.4 injectors run at roughly 100% IDC on a stock tune, which is a little higher than ideal, but putting larger injectors in (as previously stated 10 times) will not do anything beneficial to performance. People who've tuned with the injectors are just seeing gains from cleaning up the stock tune.
well i have them just because i got a good deal on them and threw them in when i got my car tuned. with the 2.4 you really don't need them if you're just into the bolt ons though. any issue's with maxing out the stock injectors are solved right away with a tune from what i've read. and injectors are useless without getting the car tuned for them so i guess it's your call.
