stock rods forged?
Old Jun 19, 2008 | 01:52 AM
mike25's Avatar
stock rods forged?
are the stock rods in our motor forged? the gm build book says they are only rated for 250hp? any truth to this?
Old Jun 19, 2008 | 01:53 AM
EceSSiveMod's Avatar
i know the crank is "forged steel" and the pistons are "heavy duty" atleast thats what the site says
Old Jun 19, 2008 | 02:00 AM
mike25's Avatar
well i know theyre rated to handle more than 250hp..the pistons may not be, but i know the rods are
Old Jun 20, 2008 | 03:37 AM
maverick0716's Avatar
I'd be very, very, surprised if the 2.4L has a forged crankshaft......that's some pretty serious hardware.
Old Jun 20, 2008 | 10:31 AM
mike25's Avatar
well i know the crank isnt forged...my prime concern is the rods/pistons
Old Jun 20, 2008 | 10:33 AM
lnf08ecotec's Avatar
The SS/SC's rods are forged...as for the 2.4L.....I'm not 100% but I don't think they are......
Old Jun 20, 2008 | 10:42 AM
elecblue06's Avatar
i'm pretty sure the rods are forged , the crank is not
everythings "rated" to 250.. but that was from a big shot of nitrous.. so it isn't the same as boost
Old Jun 20, 2008 | 10:50 AM
mike25's Avatar
thats true...i think its more dependant on how you treat the car
how big of a shot
Old Jun 20, 2008 | 10:52 AM
BoostedG5's Avatar
Yes the Rods are forged... The crank shaft is not but the pistons are curved and oil cooled to reduce friction. Lol i talked to bill hahn for an hour on his 2.4 solstice turbo build.
Old Jun 20, 2008 | 11:04 AM
elecblue06's Avatar
yea i thought thats where i got my info from but i didn't want to say that and be wrong lol
Old Jun 20, 2008 | 11:36 AM
mike25's Avatar
what allows the pistons to take so much power if theyre rated so low?
Old Jun 22, 2008 | 01:15 PM
Evil C's Avatar
They were forged in the fires of mt Doom and are imbued with Magic runes that give them a +3 to not breaking @ least thats what it says in the owners manual
Old Jun 22, 2008 | 05:40 PM
mike25's Avatar
way to be a douche troll
Old Jun 23, 2008 | 02:55 PM
alanoo's Avatar
I doubt they are... because the build book suggests you have to upgrade them at the same power level as for the 2.2 ones.
Plus as they are the exact same size and length as the 2.2 ones, I won't be surprised they are exactly the same ones
http://tunersource.gmblogs.com/Racer...06appendix.pdf
Old Jun 23, 2008 | 04:28 PM
Doesn't the 2.4L have a slightly bigger cylinder bore than the 2.2L?
It was funny, settle down.
Last edited by maverick0716; Jun 23, 2008 at 04:28 PM. Reason: Automerged Doublepost
Old Jun 23, 2008 | 08:50 PM
mike25's Avatar
was never riled up...
Old Jun 24, 2008 | 10:04 AM
elecblue06's Avatar
yes they are forged.. i some how stumbled on an sae file with the 2.4 specs in it
Type: Ecotec 2.4L I-4
Displacement: 2384cc (145 ci)
Engine Orientation: L ( longitudinal ) T ( transverse ) L / T
Compression ratio: 10.4:1
Valve configuration: dual overhead camshafts
valves per cylinder: 4
Assembly site: Spring Hill, Tenn.
Valve lifters: hydraulic roller finger follower
Firing order: 1 - 3 - 4 - 2
Bore x stroke: 88.00 x 98.00mm
Fuel system: sequential fuel injection
Fuel Type: Premium recommended not required
Block: cast aluminum
Cylinder head: cast aluminum
Intake manifold: composite
Exhaust manifold: high silicon molybdenum, cast nodular iron
Main bearing caps: aluminum bedplate
Crankshaft: cast nodular iron
Camshaft: cast nodular iron
Connecting rods: forged steel
Additional features: extended life spark plugs
extended life coolant
electronic throttle control
variable valve timing
unitized exhaust manifold/catalyst (G6)
dual converter system
Old Jun 24, 2008 | 10:09 AM
ls1fbody's Avatar
Haz l33t wheelz.
good find man.
is there anything like that for the LSJ?
im sure if i googled it i'd find it though...
Old Jun 24, 2008 | 10:11 AM
elecblue06's Avatar
Originally Posted by ls1fbody
good find man.
yea they actually had it for all the models i'll see if i can find it again and maybe i'll post it in the perf section
Old Jun 24, 2008 | 11:25 AM
celicacobalt's Avatar
what do they mean by dual convertor? I thought we only had 1 cat.
Old Jun 24, 2008 | 11:43 AM
elecblue06's Avatar
that depends on where you are.. those are also 08 specs.. but the engine internals shouldn't change
hmm i can't seem to find the 2.2 and 2.0 ones
Last edited by elecblue06; Jun 24, 2008 at 11:43 AM. Reason: Automerged Doublepost
Old Jun 24, 2008 | 01:15 PM
IonNinja's Avatar
where'd you find that at? for some reason I remember seeing that the 2.2, 2.4 and 2.0 all have forged rods
oh nevermind I see above u couldn't find the other two
Old Jun 24, 2008 | 01:24 PM
Sw4y1313's Avatar
HAH! forged rods in the 2.2 my ass!!
Old Jun 24, 2008 | 01:25 PM
elecblue06's Avatar
it's at
http://media.gm.com/us/powertrain/en...tec/08_LE5.xls
ok i found the one for the 2.2... technically it's forged but they're forged powder metal instead of forged steel like on the 2.0 and 2.4..
the one for the lsj is being tempermental right now but i'll make a new thread
Old Jun 24, 2008 | 03:46 PM
Doc's Avatar
Doc
Search for this title on gmtuner source, 104742-enginehandbook-complete-web and it says specs about the 2.2 on page 83 (the book page). It never really says if the rods are forged, it just talks about upgrading them and they are good to 250hp It says the crank is cast.
