Thinking about DP
Old May 24, 2007 | 12:23 PM
SSBOOST's Avatar
Thinking about DP
So far as you see from my sig I've got the GM intake and GM catback. I'm assuming the next smartest step would be high flow cat or downpipe. If so, which companies are producing the best ones at the moment?
Old May 24, 2007 | 12:30 PM
Rangerondubz's Avatar
I say ZZP, top quality and its cheaper than the XTC one....
Old May 24, 2007 | 01:22 PM
SSBOOST's Avatar
Is that header/downpipe combo on their site for $370 for real?!?! That is cheap as hell and not to mention like 15-20hp. http://www.zzperformance.com/cobalt_...=545&catid=155
If so which options should I get if I want the cat and I want to bolt on to the GM catback.
Old May 24, 2007 | 02:55 PM
rcmpayne's Avatar
yes that is a kit header and downpipe
Old May 24, 2007 | 07:06 PM
roccobladr's Avatar
im thinkin about going this route too. i also have the gmpp intake and gmpp exhaust.
do they make gmpp header and downpipe?
which one do you get first? header or downpipe?
and is it really worth it?
Old May 24, 2007 | 07:46 PM
Brandon97Z's Avatar
My zzp i had a while ago and a whistle noise similar to a leak, that would never go away. I don't know if they fixed it or not but i beleive it had to do with the flex section of it. Just warning ya
Old May 24, 2007 | 07:55 PM
rcmpayne's Avatar
they make a header for the ss sc not sure about the 2.4L
Old May 24, 2007 | 08:48 PM
langzhihun's Avatar
Hey if i got the GMPP Exhaust would it be compatible with force induction down the road, or are the pipes too small??
Old May 24, 2007 | 09:06 PM
SSBOOST's Avatar
This is definitely my next mod, this might actually bring me up to the SS/SC, if not pretty damn close. I'm ordering it with the high flow cat too, I don't really need to be illegal on top of how fast I drive.
Old May 24, 2007 | 10:02 PM
Jimmys2007CobaltSS/C's Avatar
that is good....im thinking about that combo as well
Old May 24, 2007 | 10:14 PM
cobaltssTH's Avatar
i have the XTC 2.5'' dp sitting in my trunk waiting to be installed. was going to do it today but had to buy 02 sensor wrench. have to wait till tomm. ill tell ya how it goes.
Old May 24, 2007 | 10:16 PM
Brandon97Z's Avatar
Originally Posted by Mahadigus
i have the ZZP ceramic coated header and d/p with cat on my 2.4... i have the gmpp cat back as well.. when u order the d/p just make sure you get the one for 2.5" catbacks... everything bolts up awesome and sounds wicked. no whistle from mine they clearly fixed that problem. had it for a few months now and its all good...hope this helps..later
thats good to hear i thought i read they were using a different flex piece to remedy the problem.
Old May 25, 2007 | 12:30 AM
Mahadigus's Avatar
must be using different ones cuz mines been fine...and you will never keep up with an ss/sc even with i/h/e and tune they are 220+whp out of the box man sorry to burst your bubble. i love my 2.4 but it needs boost or spray to keep up and thats just that
Old May 25, 2007 | 12:32 AM
SSBOOST's Avatar
my ass. i have never heard of a SS/SC at 220whp out of the box. they range from 195-208 from what ive seen. and its intake, header, downpipe, highflow cat, catback and dyno tune. but most likely you are still right, i will probably fall short 5-10whp.
Old May 25, 2007 | 01:24 AM
roccobladr's Avatar
prepare for flaming!
Old May 25, 2007 | 08:08 AM
danklite's Avatar
Man, Im glad I checked this thread out, these are definetely the next things on my list, and to be available in a combo is awesome, the 370 price is sweet, but by the time you upgrade everything to stainless and ceramic coating and such it is pushing 600, still not bad for a dp/h combo, I will definetely be checking this out, was kinda uncertain if i was even going to do this mod, as the mod bug has started to diminish ha, but i think it has regained life haha thanks zzp!
Old May 25, 2007 | 08:15 AM
johnkb8's Avatar
Originally Posted by SSBOOST
my ass. i have never heard of a SS/SC at 220whp out of the box. they range from 195-208 from what ive seen. .
i did a dyno run of 231 whp
i just had a intake
telling me my intake gave me 23 whp??
Old May 25, 2007 | 06:55 PM
SSBOOST's Avatar
maybe O_O
Old May 25, 2007 | 07:34 PM
XenSS06's Avatar
i putting 228HP / 196TQ bone stock i have the dyno sheets to prove it ill post them later.
Old May 25, 2007 | 09:02 PM
Mahadigus's Avatar
Like I said b4 even with all our bolt on's and larger injectors with tune we still if lucky will hit 180-190whp. and at the same weight as the ss/sc that still leads to us being raped on the track or the street. like i said it's boost or spary to keep up.
later
Old May 25, 2007 | 09:14 PM
sushidog's Avatar
The GMPP Exhaust is 2.25" - perfect for n/a, however a 2.5" is best if you plan on going f/i. Turbo's work on a pressure differential between ex manifold and downpipe. The greater the difference, the faster it will spin.
Old May 25, 2007 | 11:54 PM
XenSS06's Avatar
Mahadigus, Good Luck with your mods i hope you get good gains
Old May 26, 2007 | 02:11 AM
roccobladr's Avatar
what header/dp would go best with the GMPP exhaust? i have the exhaust already. im trying to keep a whole GMPP theme goin on. is there a GMPP header and downpipe? (i have no idea how these things work lol i just buy them)
Old May 26, 2007 | 11:53 AM
danklite's Avatar
^^ the only GM part offered in that combo is the extruded honed exhaust manifold, this will prove beneficial to 2.2 guys but you will still get the most out of a true header, unfortunately the only dp to my knowledge that is GM is one from a SC or upgrading that way, there is no aftermarket one, it looks like this may be one of the best options right now, I have the gmpp exhaust as well, as much as i would like to continue with the gm theme, i think that this combo will provide the most benefit, but this is also up to each persons discretion, hope that helps man, good luck with finding a good combo
Old May 26, 2007 | 01:53 PM
roccobladr's Avatar
well whats the deal with ceramic coating? is it worth the extra money? and how much louder will my car be when i put on the header and downpipe? id like to make it a little louder but i dont want it obnoxious
