tire question
Old Dec 10, 2009 | 01:20 PM
2006CobaltSS12's Avatar
tire question
My car is sitting on 205/50/17. I am looking at snow tires. Should I get the same size or a different size? Sorry if this seems like a n00b question. I don't deal with tires much.
Old Dec 10, 2009 | 01:40 PM
Illini_06SS's Avatar
I'd stick with 205/50/17's if you plan on using the same rim size. Snow tires have deeper treads and mine just barely graze the edge of my bumper at full lock if I am off-camber at all.
16" rims will fit on our car and a 16" steel rim/snow tire setup can be had for really cheap.
Old Dec 10, 2009 | 01:50 PM
Good Deal! Thanks man.
Old Dec 10, 2009 | 06:52 PM
DaBuzzard's Avatar
I went with 205/60/16's, they are only about 0.3" taller - no clearance issues.
Speedo reads about 2% under, no biggie.
205/55/16 would have been pretty much spot on for diameter but seem to be a tough size to get.
Side bonus - they ride a little softer over expansion joints thanks to the taller sidewalls
Old Dec 11, 2009 | 08:45 AM
Just for your benefit, here's the price breakdown by tire size for my tire (http://www.tirerack.com/tires/Sizes....m=05QR7AMAXA):
205/50R17: $91/tire
205/60R16: $68/tire
205/55R16: $93/tire
Old Dec 11, 2009 | 08:53 AM
D4u2s0t's Avatar
I have 215/55/16's on the car, got a full set from tirerack (both wheels and tires) for around 550 shipped. It rides significantly smoother with the smaller wheel/bigger rubber combo. Only problem is going back to summer wheels is such a difference in terms of ride quality.
Old Dec 11, 2009 | 09:40 AM
awesome! Thanks guys! I found these as well! http://tinyurl.com/yerq28k
Old Dec 11, 2009 | 03:51 PM
Be wary of "K-mart special" tires, especially if you're looking for any kind of traction. I'd suggest going with at least a high performance all-season tire if you're going to go that route.
I thought you were looking to get a second set of rims and tires for the winter and not just get new tires to replace your worn-out stockers...
Old Dec 13, 2009 | 08:20 AM
I'm exploring my possibilities.
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
DANRICKARD
Oct 1, 2015 12:08 AM
