TOP speed for a Stock 2.4
Adding an intake and stuff like that won't increase your top speed...the speed is regulated by the duty of the injectors and when they cut out...also, aerodynamics also take part in what the top speed is...drag restriction...
The pirelli p-zeros were w-rated from the factory I thoguht...
I have hte SS/SC rims now iwth the SS/SC stock tires wrapped around them I believe they are z rated not 100% sure though so don't quote me =\
Originally Posted by kadumel
Actually the speed rating on W-Rated tires is 137 miles per hour
nope, w rated.
Originally Posted by mike25
notbein ignorant....bt if you implying your car will go faster due to erodynamics...your mistaken...our cars are the same as your excpt for a body kit...n diff. there...and a huge ass wing
I think your miss-reading his post. He just said areodynamics play a role--which they do.
Originally Posted by Brenn8402
on the windows sticker my car said it had z rated tires, but i have the h could the computer think they are z??
yeah my dealer wanted to sell me the tire warranty. 8.95 a month and if i hit a pothole or get a flat and i ruin the rim, GM Buys me a tire and rim for free...but then they said my 4dr SS 2006 had z rated according to the window sticker and they couldnt give me the warranty. i got home and i have 205/50/r17 90H rated..soi called them back, they are going to have me come down tomorrow so they can see
Tires won't affect your top speed, nor any mods short of a flash or new chip. The rating on the tires only allows you to go a certain speed safely (the speed rating on the tires gives the approximate speed at which the cetrifugal force on the wheel will begin seperating the tire from the wheel). Mods (bolt on's) and aerodynamics won't increase your top speed, only how long it takes you to get to the top speed and the safety/handling at that speed. My Stage 0 SRT-4 has a top speed of 138 on account the governor won't allow my car to go any higher. After i got a new chip (Stage 1), my governor didn't cut me off until 160, which is redline in fifth gear. Hope this helps.
ahem
When I am reading something from an unknown source, I like to read about things that I already know (tires), so that I can decide to trust what I don't already know (engine mods).
I some guess US 2.4L have the Z rated tires--but mine are H
Originally Posted by mi6_
The SS/SC has W-rated tires. They are good for 168 MPH. The Cobalt SS 2.4L has H-rated tires that are good for 130 MPH. Any tire that is speed rated to at least 149 MPH is considered "Z-rated".
Actually in fact you are completey wrong. The tire rating is determined at what speed, if kept constant for I believe 5 hours, does your tire begin to burn away.
Originally Posted by BLKSS
So you believe that he is completley wrong? What he said sounded pretty right to me. I think your just full of **** all the time.
I think you just got owned...
Next time before you open your mouth, think about how stupid you look when you go around trying to find crap to stir up.
http://www.nhtsa.dot.gov/cars/rules/.../brochure.html
Speed Rating
The speed rating denotes the speed at which a tire is designed to be driven for extended periods of time. The ratings range from 99 miles per hour (mph) to 186 mph. These ratings are listed below. Note: You may not find this information on all tires because it is not required by law.
Letter Rating Speed Rating
Q 99 mph
R 106 mph
S 112 mph
T 118 mph
U 124 mph
H 130 mph
V 149 mph
W 168* mph
Y 186* mph
* For tires with a maximum speed capability over 149 mph, tire manufacturers sometimes use the letters ZR. For those with a maximum speed capability over 186 mph, tire manufacturers always use the letters ZR.
