Traction Control
Traction Control
This morning 5 " of snow. tires spin, traction light on, no move. No power to wheels. pull up a notch on e brake, pulled out of the snow out of the driveway and up the hills to 684. What gives, first car with TC. Is this how it is supposed to work? Could my B&M shiftplus unit being on cause this. Dealer problem?
Yeah but when your turning out onto a busy road with a 55 speed limit and suddenly about 4 foot into your turn poof your wheel power cuts out and for 2 seconds my first thought is "oh **** i hope that guy dosent slam into me" then the car starts moving slowly. TC is honestly the scariest crappiest option on my car and it can't be turned off.
I know what you guys are saying about the shifting and the E brake method but when you have been driving for 11 years w/o having to down shift in a auto fwd car just to avoid having your car potentially kill you its not really what i would call a natural thought.
if i could disengague the e brake dinger id drive around with the e brake up one click all the time.
Chev should not call that "feature" Traction Control - it should be called "Emergency wheelspin fuel cut" and it is LAME because it does nothing to actually help your TRACTION out!
Someone needs to come up with a switch to shut it off. Seems like you could tap in to the wires going to the ABS wheel sensors and create a loop that fools the pcm into thinking the tires are all spinning at the same rate even when they aren't.
i dont have the TC in my g5 sence its a 5 speed put i do have it in my cavalier. 1st and sec gear the TC is off then 3 and D its on. when your hiting the gas and the cars just stuck and its makeing that funny pop pop sound you have to turn the TC off and give the car some gas to spin its way out. my cavalier is the same way and my dads malibu is. the TC is so you dont lose traction geting up a hill once the light turnes on keep on the gas thats what i always did and it would pass everyone stuck on the hills. my sunfire had the switch to turn the TC off the cavalier dont.
.....or you guys could ditch the B&M Shiftplus and rinky dink e-brake methods and get an HPTuners tune. Not only can you do more than the B&M Shiftplus unit, but you can also disable traction control completely. Best part: it'd all be on the factory TCM rather than some intrusive extra unit and half-assed workarounds.
