tune or jet chip or both
alright im going to be fully bolted soon, would i benifit from the jet chip and clear image tune, or should i just get the tune or just the chip and why.
do you want to learn? if so, forget the other options, buy hptuners and start learning.
if you don't want to learn, don't get a tune. save the money for mechanic's bills and keep your warranty.
to answer the original question, there is zero point to having both. the custom tune would definately be better, the only advantage I see to the jet chip is that its easily removed should warranty work be required. and Im not sure but I think the jet chip is cheaper
He's asking about the Jet Chip module, a plug-and-play tuning device that gives more performance
It mounts on the ECM (middle connector) and uses the ECM's input and output signals to change the timing, fuel, and Tranny shifts....i.e....a piggyback device. I went with the Jet Chip module and am happy with it -- I don't want to take it out and feel the lousy low-end power again!
If you can afford the HPTuners AND can tune your car that's cool, OR if you know someone that CAN tune AND can TRUST them that's cool too, BUT if you are like 90% of Cobalt owners and don't know how or don't know/trust anybody that can then this "$239 + shipping" Jet Chip module could make you happy! I recommend it...but then again, can you trust me?
....and it's one or the other, don't get both!
I also think the wording "custom tune" is overrated. I seriously doubt there is enough difference between 2.2 equipped Cobalts or 2.4 equipped Cobalts that you can gain any identifiable performance gains. Ignition timing and fuel burning is more of a science than magic.
well its custom in the sense that if you have aftermarket parts, he takes that into consideration and tunes accordingly. so example...my tune isnt too complicated because i am completely stock and use regular 87 fuel, so he just does a few things to it. now, Tom [NWAE Cobalt] has a more complicated tune because he has cai, exhaust, some other little random things and uses premium 92 fuel so Vince tunes for that. I use the words "custom tune" because its not a canned tune. Vince mails you the stuff, you upload it, give Vince some input, work with him a little and send the little package back.
To help Red07,
I got the tune this week from Vince at Trifecta.
The PDA uploads the tune to the car, car resets and is ready to start.
Also, i needed a few things changed so he emailed me an update, i uploaded it to an SD memory card and put it in the PDA. Worked like a charm, quck and easy.
Service was great, i talked to Vince several times before returning it.
What the jet chip does is interrupt the signal from the ECM and adjust it to its preprogrammed standards. So if you did do a tune to your ECM... any benefit would be lost because the chip changes it.
I was big on trying to get details and results about the Jet Module. I still think tuning will give you the best results but this is a simpler and removable option.
