Uh Oh?
Hey everyone,
I have the Magnaflow exhaust catback for the 2.2L (2.25inch) on its way to me. The person I talked to at Magnaflow said either the 2.0LSS/SC or the 2.2LSS would fix my 2.4LSS. He recommended I go with the 2.2L. I said giddyup, and now I just read the new post by avro206 "straight from GM". I hope I understood it incorrectly because I think it said something along the lines of the 2.2 and 2.4 parts are NOT interchangeable...so my question is, did I screw up royally by getting this Magnaflow exhaust?
(ps I have a leased 2.4L, the stock exhaust is bolt on and so is the Magnaflow. The performance buff manager from Don Howsen Chevrolet said I can pull this off without messing with warranty)
well ive heard both ive heard the 2.4 can use 2.0 parts then i hear that it can use 2.2 parts so i dont know what to belive anymore but magnaflow says on their website that the 2.0 and 2.4 are the same exhaust
the 2.4 looks to use the same cat back as the 2.0 s/c , which both are 2 1/4"
from what i understand
id jack the car up when you get the exhaust and do a trial fit , with out removing the stock exhaust , if things line up go for it , if they dont box it back up and send it back
The only way to be certain is to compare them side by side or try to install it. It seems that you are too late anyways to change the answer...
If it does not fit, Sell it and try to get some of your money back..
To clear any confusion.
The 2.4 SS and the 2.0 SS use the exact same "tuned exhaust". Larger piping, and large tip. The 2.2's use a normal exhaust, usually non-tip. Smaller tubing. But the actual mounts themselves for the exhaust are probably the same. I know you could use the 2.0 SS exhaust perfectly. But I'd say you should be set with the 2.2 too. But don't 100% quote me. Good luck. Certainly get pics and video/sound if you can after the install. I have a leased 2.4 SS too and I'm VERY curious...
im sure it should bolt right up no problem cause ive ben to web sites that say magnaflow for 2.2 and 2.4 so im think it should be fine ive heard that u can use ss/sc exhuast too but im sure theres not a difference eitherway....
each motor is going to have different needs as far as the exhaust goes , and each company is gonna be different with what they produce
but each car will take to mods different from the next car
the guy at Magnaflow said that the Magnaflow performance catback for the SS/SC is 2 1/2 inch and the mangaflow performance catback for the 2.2L is 2 1/4inch. He highly recommended I go with the 2.2L setup, so of course i take his professional opinion and am still waiting for my shipment.
