Valve Spring Compressor
Old Nov 12, 2017 | 05:11 PM
Henry3959's Avatar
Has anyone used a different valve spring compressor than the Kent Moore tool?
Is anyone leasing this tool or another like it on the forum.
Old Nov 13, 2017 | 07:52 AM
cw383's Avatar
I can hook you up. How long would you need it for?
Old Nov 13, 2017 | 08:32 AM
jdbaugh1's Avatar
I used this one. I used this one.
Old Nov 13, 2017 | 09:01 AM
cw383's Avatar
Lmao! Is that in your living room? Love it! Or super nice work area. I did mine in my basement and had to roll it out up the steps myself
Old Nov 13, 2017 | 09:03 AM
jdbaugh1's Avatar
Yes it is in my living room lol. I don't typically do work in there but the keepers on the valves are so damn tiny and I didn't have any extras and I didn't want to lose any so I brought it in on the wood floor so I would be able to find on if I dropped any.
Old Nov 13, 2017 | 09:06 AM
Henry3959's Avatar
When my parts arrive, only a weekend. Probably not this coming weekend.
Old Nov 13, 2017 | 09:12 AM
cw383's Avatar
Yes, word to the wise, plug the oil galleys with shop towel wads. My first LNF still has a retainer floating around in there somewhere. I have a valve spring set like that red one too. If it has an air chuck for the spark plug hole watch that thing if your doing an on engine job. Mine had a shrader valve in it for some dumb reason and it wouldnt pressurize the cylinder and I found that out the hard way when I touched the valve stem and it vanished before my eyes! I never would of thought they would have put one in there. Ended up dropping a valve during a spring swap as a result. I was able to pull the intake and use a piece of metal brake line with some tie wire forming a loop inside it, and it was a PITA, but eventually i got it into the guide. Stupid things to watch out for....
Old Nov 15, 2017 | 01:38 PM
steelmesh's Avatar
A poorman alternative is to buy one of
these cheap ones these cheap ones
then make the adapter cup. Use conduit then cut out a notch as needed to access the keys, the shape is sort of like this -> http://www.lasertools.co.uk/items/large/5495_Right.jpg.
---the editor isn't working right, got some weird link stuff going on
