Vibrant Header/Downpipe
Alright I decided to go with Vibrant Header and downpipe bought one off of a member of this forum. He states that the header and downpipe should fit a 2.4L, the only thing is my car is an auto. I've heard I may need a TTR mount, if so what kind of TTR mount do I need? Also how much of a tight fit is it?
Here is the AUto Trans upper engine mount you were refering to:
Turbo Tech Racing Solid Upper Engine Mount Chevrolet Cobalt 2.2/2.4L HHR 2.0/2.2/2.4L Auto Trans - Drivetrain - Turbo Tech Racing, LLC
He's wrong. There is fitment issues with this set up, I should know I spent nearly six hours trying to custom fabricate it to fit my car, with no luck. The downpipe rubs under mild acceleration and makes a terrible grinding noise.
What about with the TTR mount? Does it help out any?
I'm an Auto. I have the Vibrant Header/DP. You NEED a solid upper mount due to rubbing issues w/ the header/dp. After that easy installation with the mount, there will be no rubbing. Take it from me. There are very few Auto 2.4's with this set up.
I'm not sure what "fabrication" you're referring to. I simply put the header/dp in and noticed later on that there was a rubbing issue. I simply figured out what the issue was and realized that I NEEDED a solid upper mount. Problem solved.
This is true, the "slop" in the stock mount, that is worn, causes issues. As stated the TTR Upper mount makes it work.
Yes, the motor is clocked forward a few degrees in the Auto. Please note that most, if not all, exhaust systems are fabricated using a manual car as a donor. Not too many brands take these Autos into consideration. At least thats what I have concluded lol
So where is the upper engine mount anyways?
The upper mount is located just left of the motor. Cant miss it. Look for a How-to since you're a bit new at this. It's a simple installation that requires basic tools. Took me 30min to complete. Everyone was a noob at one point. Just remember... I never said that the Header/DP installation was gonna be easy.
I have another one, what about if I want to do an 02 wide band receiver? I want to also check how much air I'm getting.
Cool Thanks man, yeah that sounds like a plan, I saw where the Mount is at, I have a K&N Typhoon so I guess I'll have to completely remove it in order to get in there lol. Thank you for answering my questions.
It's ok, Alright I'm gonna try to set it up today, the only problem I had yesterday was trying to take off the bolts for the Header and downpipe, Should I use power tools? I'll have to borrow some from a friend and all. Oh and I have the motor mount from TTR coming my way to, Any other advice?
heat the bolts up with a hand torch if they arent coming out, thats what i had to do when i put my catback in. i spent 4 hours and 3 cans of pb blaster then my friend said lets try a torch and within 2 minutes they were out
edit: not the header to engine blots just the downpipe to cat back bolts
noooo dont pay someone trust me you can get them, torch those too just be careful not to heat the actually head up too much. as long as you take your time im positive you could get them
I did smell an exhaust smell for the first 5 minutes but after that, the smell went away complete, it is a used Vibrant afterall lol. But no lie it was sort of a pain to install at first but after getting those bolts out from the header and downpipe it was all easy. Over all I have to say that I like this install feels more complete but I won't really say that until I go super
Problems now are occuring since the install, the new gasket I bought from AutoZone blew and there is a major exhaust leak is occuring and it sounds way to loud, I don't know what to do, I worked on this sucker 3 times already one before just because the bolts are to big the person I bought it from never gave me the bolts nor the gasket
I have had mine in for a year without the solid mount and don't see or hear any rubbing. I only have 32k on this car so maybe the stock mount is still stiff.Take into account that I will replace this in time as the aftermarket has to be alot better.
the exhaust leak is at the gasket right? did you torque the bolts in the right order? you might not have blown the gasket maybe you just didnt torque them the right order. in this thread theres a picture of the order your supposed to do.
https://www.cobaltss.net/forums/how-...wnpipe-158475/
but if you did already do this i would say buy a gasket from zzp, i know theirs are good. you could ask them about the header to cyl head bolt if thats what you were talking about.
