wideband
Old Aug 17, 2012 | 10:24 PM
yogilours's Avatar
wideband
i want to know where to put the wideband with the zzp 2,5 dp catted before the cat near headers or after the cat near catback and my o2 sensor is bypass
thanks!
Old Aug 17, 2012 | 10:39 PM
09CobaltSS1's Avatar
You always want your wideband to sit before the cat as close to the header collector as possible.
Old Aug 17, 2012 | 10:48 PM
yogilours's Avatar
ok so if i put after the cat the reading would be wrong ?
Old Aug 17, 2012 | 10:57 PM
yes it will skew the readings
Old Aug 17, 2012 | 10:58 PM
yogilours's Avatar
ok so i have to weld a bung before the cat ?
Old Aug 17, 2012 | 11:15 PM
hhrfreek's Avatar
Do you have the dp already? If there is no bung before the cat then yes you need to weld one in. If you are buying a new zzp dp then get it with the extra bung for wb.
Old Aug 18, 2012 | 12:00 AM
yogilours's Avatar
ok thanks!
DarrenGC
Dec 24, 2021 01:55 PM
n20saturn
Sep 30, 2015 12:26 AM
xxenjoi11
Sep 29, 2015 12:36 PM
n20saturn
Sep 21, 2015 01:50 AM
