zzp 2.5 downpipe
Old Jun 22, 2012 | 11:09 PM
CHEVRO_SS's Avatar
zzp 2.5 downpipe
if i buy this do i need to add a o2 bung so that my car does not throw any codes or do i just get the dp with the cat and ill be good?
Old Jun 23, 2012 | 12:05 AM
noorj's Avatar
Come on man, your not new. This has been reviewed many times, use the search.
Yes you will need one, here:
Exhaust - Vibrant Oxygen Sensor Defouler
Old Jun 23, 2012 | 12:09 AM
chevygirl2006's Avatar
Ya get the extra o2 bung. Mine didn't throw any codes
Old Jun 23, 2012 | 12:16 AM
mtbrent's Avatar
Xtra o2 only if you plan on using a wideband, otherwise no need.
Old Jun 23, 2012 | 12:17 AM
winning_blue's Avatar
this
Old Jun 23, 2012 | 12:20 AM
I'm not using a wideband and I got the extra one. The only reason I got the extra one is so my tuner could use his wideband to tune my car.
Old Jun 23, 2012 | 12:33 AM
mtbrent's Avatar
Yea, essentially if you think you may ever use a wideband, get the extra bung. Plugs are cheap for when you don't have anything hooked up.
Old Jun 23, 2012 | 03:12 AM
CHEVRO_SS's Avatar
sorry, but is there a way to get rid of the code if i dont get the o2 bung?
Old Jun 23, 2012 | 03:28 AM
Tune it out
Old Jun 23, 2012 | 03:32 AM
CHEVRO_SS's Avatar
Tune it out
how much does that cost? also do u know if the zzp 2.5 dp comes with o2 bung for the one thats on the stock dp..or do u actually have to add the extra bung in order to plug in the stock o2 sensor
Old Jun 23, 2012 | 03:35 AM
It comes with one for ur o2 sensor But u have the option to add an extra for the wide band. Normal tunes are usually around 250.
Old Jun 23, 2012 | 03:38 AM
CHEVRO_SS's Avatar
im sorry guys i dont really know much about down pipes and o2 sensors i guess but all i want to do is get a new downpipe and for me to not have ANY codes coming up...what do i EXACTLY have to do...again sorry
Oh and if you get the extra o2 bung make sure to get an o2 bung plug so you can plug it up while you aren't using it.
Old Jun 23, 2012 | 03:39 AM
CHEVRO_SS's Avatar
oh ok so i dont have to add a extra bung and all o have to do is plug my stock o2 sensor into my new dp and i will be fine? with no codes?
Old Jun 23, 2012 | 03:40 AM
Get the zzp catted 2.5 downpipe. Get the extra o2 bung. Go to an exhaust shop and they will give u an o2 bung plug. My zzp downpipe threw no codes
Old Jun 23, 2012 | 03:42 AM
You don't need the extra one unless you plan to use a wideband. My car didn't through codes with my downpipe. It did when I added then header though
Old Jun 23, 2012 | 04:03 AM
CHEVRO_SS's Avatar
so u didnt get the extra 02 bung and urs throws no codes?
i got 2 ppl telling me different things now lol
so u got the extra o2 bung and u put the plug on it? and it throws no codes b/c of the plug on the o2 bung?
I did get the extra one. But u don't need it unless u plan to use a wideband
Old Jun 23, 2012 | 04:05 AM
CHEVRO_SS's Avatar
oh ok but if i dont get it my car will throw codes?
Old Jun 23, 2012 | 04:08 AM
Im not sure. I don't think it will. And if ur cel comes on it's not harming ur car
So your car isn't tuned already?
Last edited by chevygirl2006; Jun 23, 2012 at 04:08 AM. Reason: Automerged Doublepost
Old Jun 23, 2012 | 04:10 AM
CHEVRO_SS's Avatar
also do i need the Vibrant Oxygen Sensor Defouler that noorjariri posted about?
Old Jun 23, 2012 | 04:12 AM
CHEVRO_SS's Avatar
no it is not tuned...if im thinking about getting it tuned i should get the extra bung?
I didn't get it.
Old Jun 23, 2012 | 04:14 AM
Ya so you can use the wideband. And it's best to get tuned because it brings out the full potential in ur bolt ons. If you don't ur not going to see much of an increase in power
Old Jun 23, 2012 | 04:15 AM
CobaltItaliano's Avatar
get the extra bung. never know if u will ever need it. plugs for it are cheap so do it the right way first and get it.
