2.4 intake manifold/tb on LSJ
Old Sep 3, 2008 | 06:24 PM
Maxim_X's Avatar
It looks like it will fit but there is an AC hose close. I'm just wondering if anyone has bolted this manifold up.
Also do the 2.4 throtle bodies hook up to the lsj wiring and perform as stock? I have a spacer to make the lsj throttle body work but the holes aren't perfect so I will have to do some machine work. I was just wondering if the 2.4 throttle body will work.
Old Sep 3, 2008 | 06:26 PM
XM15's Avatar
So why are you are wanting to replace the 2.0 IM?
Old Sep 3, 2008 | 06:28 PM
Halfcent's Avatar
I'm old school
The LSJ uses a laminov cast aluminum heat exchager manifold with a mount for the supercharger. The LE5 is a piece of plastic. Why would you even want to do that? You wouldn't be able to use the supercharger any more. Are you going turbo or something?
I guess to answer your question, yes the manifold will physically bolt on just fine. I can't be sure about the TB, but I bet it wouldn't be hard.
Old Sep 3, 2008 | 06:29 PM
o3nisoaso3's Avatar
umm... why would you want a 2.4 manifold? is it actually bigger? and i thot that a h/e or one of your cooling mods ran thru the IM? (im not too educated on lsj's so dont laugh if that was a retarded thot)
if i typed faster i woulda already read that post bout the h/e
Old Sep 3, 2008 | 06:33 PM
XM15's Avatar
Yeah, he is turbo.
My guess is he is looking for a cheaper alternative to the Hahn manifold.
Old Sep 3, 2008 | 07:28 PM
freakta's Avatar
ya its turbo and the 2.4 mani looks to flow alot better than the 2.0
Old Sep 3, 2008 | 09:31 PM
Maxim_X's Avatar
Yes the supercharger is gone. That's not an issue. Design wise the 2.4 manifold is actually very good. I was really wondering weather anyone has done this before and if it would have clearance it the LSJ motor. I know it will physically bolt up but I'm not sure if it will clear a specific AC line.
Originally Posted by XM15
Yeah, he is turbo.
You got it. The TB placement is better for me too.
Old Sep 3, 2008 | 09:37 PM
Halfcent's Avatar
I'm old school
If it just a AC line you are worried about, remove it and make a new one that fits. You obviously are going to have to discharge your AC system to do that, but for the amount of money you are going to spend on the turbo, who cares.
Old Sep 3, 2008 | 09:46 PM
Maxim_X's Avatar
Yeah If it's an issue I will probably go to a saab intake mani. I would rather not mess with AC stuff. LoL @ going to spend on the the turbo, I've already spents thousands and been turbo for months going threw 2 turbos already.
The line is a hard aluminum line connected to a bracket so I am really reluctant to mess with it. I guess I will find out if I'm the only one.
Old Sep 4, 2008 | 07:21 AM
Bill@usd's Avatar
the l61 and le5 don't work the lsj head
the saab manifold fit perfectly
found on ecotec hybrid site http://www.ecotecforum.com/forums/showthread.php?t=5344
Old Sep 4, 2008 | 09:48 AM
Brandon97Z's Avatar
If 2.4 guys are using the IM/SC of the 2.0 i couldn't see why it wouldn't fit.
Old Sep 4, 2008 | 08:25 PM
Maxim_X's Avatar
X2 I see the pics and thanks for the info but I was sure it would bolt up I was just worried about clearance. Now you got me all worried if it will even bolt up. I Don't know how the LSJ intake manifold fits on the 22 and 24 then.
Old Sep 6, 2008 | 12:50 PM
Bill@usd's Avatar
what I talking about...
Old Sep 6, 2008 | 03:03 PM
Maxim_X's Avatar
I see, what does that hole do? Is it part of the air intake?
Old Sep 11, 2008 | 03:15 PM
Maven's Avatar
YYou cant put an NA ECO manifold onto an LSJ head because they dont cover the crankcase ventilation port in the LSJ head, which means youll blow oil all over you engine bay.
You can put an LSJ manifolde onto an NA head because the LSJ head covers the crankcase ventilation port so theres no oil to blow around(you just have to modify the intake gasket so the NA heads little ventialion port can vent to the LSJs spot.)
These holes are the PCV system.
Old Sep 11, 2008 | 08:26 PM
Maxim_X's Avatar
Thanks guys. I see the problem now. I'm going with a saab mani.
Old Sep 12, 2008 | 06:23 AM
Speedytec's Avatar
Can you post a pic of that saab intake manifold when you have it?
Maybe another option is the new Turbo LNF intake manifold. Think that should fit the LSJ head.
Old Jan 31, 2009 | 01:53 PM
Dayta's Avatar
what year/style saab intake manifold is that? i need one and dont really feel like gettin the wrong one...
Old Jan 31, 2009 | 02:11 PM
Red07SSNA's Avatar
Correct --You can put the LSJ mani on the L61/LE5 BUT you have to cut the manifold gasket to get the PCV system to work -- the how-to is in the Ecotec build book...
Old Jan 31, 2009 | 02:48 PM
Blown 4-banger's Avatar
I'm making the L61 manifold work on my head, even if I have to clean the engine bay ever day or so.
Old Jan 31, 2009 | 05:00 PM
Maxim_X's Avatar
Back from the dead....
You can tap that port and put a fitting and tube on it and send that into the intake mani. I just picked up and LK9 intake manifold. With a little modification to the throttle body and spacer the inlet on the manifold it should be the perfect solution. It was cheap too, less than 150 with a gasket from the dealer. That cheaper than what most 2.4 mani's go for.
I should make a how to....
Old Jan 31, 2009 | 06:08 PM
Maven's Avatar
Yeah the LK9 manifold is very cheap and bolts right up to LSJ(same head afterall)
Old Jan 31, 2009 | 08:01 PM
Maxim_X's Avatar
DId you use it? WHat did you do to bolt the TB up?
I have a spacer from the SC delete kit but I still need to do some work to make it all fit perfect.
Old Mar 2, 2009 | 09:31 PM
mattcossel29's Avatar
or you could weld the crank case vent up.. or have someone else do it
Old Mar 2, 2009 | 10:15 PM
Maven's Avatar
Yeah, that sounds like a good idea.....weld the PCV system shut. So instead of using the proper manifold youll just have to engineer a new crankcase ventiltion system.
