8.5:1 Pistons!?!?
#51
No, the stock ss s/c rods are rated to like 450-500 hp. There based off the Pink rods for the small block chevy. The stock rods are forged, and people don't give them enough credit, just because they are stock. Think about this, have you EVER heard of stock LSJ rods failing? I sure haven't, many people have had pistons fail, put forged pistons, and never have any more problems. The rods are good, hell Rice eater's crank failed before the rods did!
#52
The build book says not to use them in applications over 300hp. My machine shop said it was not a good idea to use them. I told them that they are similar to sb Chevy pink rods, but they said they would be inadequate. I'm not saying they will fail, I just figure while it's apart why not?
#54
LSX RWD S/C conversion
#57
In the LSJ build book it says the stock rods "...are more than capable of handling 300 hp..."
I can not afford the JBP rip off rods, it would be cheaper to get a set custom CNC machined.
#59
Yeah I saw that too... It seems like there is so much conflicting info out there. I didn't want to take the chance so I just got some eagle rods and had the crank machined.
#61
#66
So did you end up getting any sleeve damage? Any pictures of the piston?
I would wait and save to do it right the first time. You probably don't want to open this motor up again. I know my car has been in the air for 5 months now.
#69
#70
ok I am starting to follow this thread.... I am running the 2.2 headgasket so if I read everything right then I shouldnt go anything less 9.5:1 because it will increase the chances of detonation?
#72
No. Lower compression decreases the risk of detonation. The more boost you want, the lower the compression. As for the 2.2 gasket you should be ok. It is slightly thicker than the 2.0 gasket so it lowered your compression slightly.
#73
Damn George! You tell him that the thicker gasket is cool, but I get bitched at by Cameron for throwing out the idea of a slightly thicker gasket! So what's the deal, is it okay on a boosted motor or not?
#75
yo cameron how is the build coming along?, and i showed my cousin your fly by video and he pretty much was like HOLY ****!!!! and im leaving florida guys, talk to you guys when im back in new york peace!!!!
