anyone running straight meth?
ok so i recently got the snow performance stage 2 kit for the balt and after install and tune i seem to be using alot of methanol. the 2 quart resevour is empty after about three days. i know some might say to keep my foot out of it but thats just it, i don't drive my car hard. except on weekends and even then i don't drive it real hard. i went to the track the other day and made 4 passes and didn't use hardly any. it just doesn't make sense. i was told that if i change the start voltage to a higher setting that it would help. but the damn dial doesn't have a make to tell me where its at right now. so i don't know where to take it. any help would be awesome. thanks
i am running straight methanol by the way.
Are you spraying before or after the throttle body? If after, make sure you have a check valve that is actually working.
Distilled water cools the temperatures better than Methanol, hence why most run a 50/50 mix. To get the best lower temps and increased octane rating.
Don't run straight, run 50/50 and my god, how are you running through that much in 3 days. It takes me like three weeks to go through 2 quarts. I think you have it kicking on to early or have a bad leak somewhere.
see that is what i think also. but like i said there is no indication on the dial as to where its at now. where do you have yours set at if you don't mind.
and i just may have to go to a 50/50 mix. cause that **** is expensive. but the reasone that i went that way was because water is corosive and don't like the idea of putting water in my motor. but i guess if its distilled......
and i am spraying it into the intake before the TB
well see yours is off boost and mine is off MAF. so hell i don't know. i might just have to play with it some more and see what it does.
where is you IAT amd IAT2's? also where did you put your timing?
i have tried to call him like five times in the past week. he just doesn't answer. did you ever get yours put on? i messed with my start voltage and i'll see if that helps.
yeah i got it all on i have tried to call him too like 5 times cause i need a tune for my 2.6 and meth... i would almost say that your meth is coming on to early...i wish you luck with that .. if you get ahold of rob can you let him i know i need a tune real badly
I run the snow performance stage 2 kit on mine...no MAF controller right, just the boost switch right?? I'd check wat nozzle size you had in first. Second I only have my kit come in about 2 psi before max b/c I dont have the progressive controller but I really dont need it b/c at WOT it instantly got to max boost pretty much ya know...snow performance recommends having it come in like that when you dont have the progressive controller...
Also, idk how much u beat on your car but mine usually last me a couple weeks and I'd say I get on it about 4-5 days outta the week maybe once or twice a day..."spiritied" driving at times on the way to work...
