bykryder83 build thread
Soo after 2 years of building the balt, I've finally decided to post a build thread. I hope everyone enjoys it....
Platform: 2006 chevy cobalt ls, no options bone stock, lightest model u can purchase. Ultra silver metallic. 5 speed. Engine: 2.2 liter fully balanced and built by polareck engines Darton sleeves Wiseco 8:9.1 comp pistons Eagle h-beam rods arp rod bolts Stock crank, micro polished,balanced, and lightened Clevite h-series rod berings Clevite main berings Arp head bolts and gm main bolts Cometic head gasket Port and polished head Supertech oversized valves Supertech valve springs, retainers kit Comp cams turbo grind cams Bates valve guides,and seals Bates oil pump gears Level zero balance shaft delete Vulcan coolant tank Zzp phanolic (sp) intake spacer Modified lsj valve cover, to fit 2.2 Bwoody engine and trans mounts Zzp fuel pump rewire Walbro fuel pump Ottp return style Zzp 80lb/hr injectors Lsj fuel rail Lsj throttle body ls4 throttle body Bates oil pump gears Ari crank pulley Mrz alt pulley lsj map sensor a/c delete Trans/drivetrain: Fidanza flywheel zzp adj clutch rod arp flywheel bolts Spec stage 3 clutch Zzp clutch rod Ksport coilovers Zzp control arms Suspension tech front sway bar Progress rear sway bar Drilled and slotted rotors russel stainless braided brake lines Twm st16 inch rota circit 10 rims with bfg kdw 2 tires...225/45/16 Turbo: Precision 6262sp Precision 46mm wastegate Tial 50mm bov Hahn intake mani Zzp turbo mani Hahn intercooler piping Precision couplers and t-bolt clamps Cxr intercooler (huge) 12x4x30 body/appearance: cobalt ss/sc front bumper and lip tinted tails debagded painted bowtie,3rd brake light,and side markers zzp triple gauge pod autometer boost and oil pressure aem wideband fiberglass racing buckets with nrg 5pt harnesses ark shorty antenna There is more, I will update later as I'm @ work lol :) enjoy |
That is a shit ton of mods lol
It seems like it's gonna be a sweet build Good luck with it :twothumbs |
is that it? :lol:
o my shes finally coming together
about time :lol:
I forgot to put a lot on that list but I'm @ work and my droid is a piece of garbage, soo ill wait till later to finish the list and try to post pics....only prob right now is she will not start!! Says reduced engine power and engine disabled :(
i still got the pics u sent me i think :D lol
Thanks guys, its been a long ass time in the works..I've had kids since I started the build and changed my mind a million times ect. Lol.........rico thought ud like this :D
Kxrider thanx man, how's ur car c@oming along? Did I point ya in the right direction?? Thanks guys, its been a long ass time in the works..I've had kids since I started the build and changed my mind a million times ect. Lol.........rico thought ud like this :D Kxrider thanx man, how's ur car c@oming along? Did I point ya in the right direction?? |
haha yes i wanted u to post it up :p:
Rico! Post them up if ya can/would?? Id appreciate it man
Niceee!!!!!! Ill post more later
it is better i think something is going on with my throttle body cause im throwing tps codes but when i rev the car when it comes down it dies so im still trying to figure out the issue and a new bov fixed the flutter issue
man all this and you didnt even say thanks for lettin you use my garage... haha. jk man. ill take some pics with my galaxy S and post them up.
Update: I fired it up this Saturday, just to see if she would run....yuppp!!!! Sounded like a freaking beast!
Now I need a good tune,downpipe and side exit exhaust and ill be ready to drive her after 2 long ass years of waiting,changing my mind,short on cash ect.! I'm planning on breaking into the 10's with this car so wish me luck.. |
hurry da eff up :lol:
I'm tryin in tryin lol, shortage on funds again...
true my car might be randomly selling
Zzp 3 inch turbo downpipe (custom)
Zzp wastegate dump tube Magnaflow 3inch race muff 3inch side exit exhaust Trifecta tuned CAR IS RUNNING!!!!!!! |
vids and pics!!!
Working on it lol. Tryin to wrk some probs out
i know how that goes lol
NIce work! I just found this thread, 2.2 love.
Update?
Got more pics and vids....took some pulls last night@ 15 psi. Tires just spin all the way to 120! Clutch is slipping and im not even at 35 psi yet lol! Hopefully steve will post up the vids
