bykryder83 build thread
Old Aug 16, 2010 | 09:43 AM
bykryder83's Avatar
Soo after 2 years of building the balt, I've finally decided to post a build thread. I hope everyone enjoys it....
Platform: 2006 chevy cobalt ls, no options bone stock, lightest model u can purchase. Ultra silver metallic. 5 speed.
Engine: 2.2 liter
fully balanced and built by polareck engines
Darton sleeves
Wiseco 8:9.1 comp pistons
Eagle h-beam rods
arp rod bolts
Stock crank, micro polished,balanced, and lightened
Clevite h-series rod berings
Clevite main berings
Arp head bolts and gm main bolts
Cometic head gasket
Port and polished head
Supertech oversized valves
Supertech valve springs, retainers kit
Comp cams turbo grind cams
Bates valve guides,and seals
Bates oil pump gears
Level zero balance shaft delete
Vulcan coolant tank
Zzp phanolic (sp) intake spacer
Modified lsj valve cover, to fit 2.2
Bwoody engine and trans mounts
Zzp fuel pump rewire
Walbro fuel pump
Ottp return style
Zzp 80lb/hr injectors
Lsj fuel rail
Lsj throttle body
ls4 throttle body
Ari crank pulley
Mrz alt pulley
lsj map sensor
a/c delete
Trans/drivetrain:
Fidanza flywheel
zzp adj clutch rod
arp flywheel bolts
Spec stage 3 clutch
Zzp clutch rod
Ksport coilovers
Zzp control arms
Suspension tech front sway bar
Progress rear sway bar
Drilled and slotted rotors
russel stainless braided brake lines
Twm st16 inch rota circit 10 rims with bfg kdw 2 tires...225/45/16
Turbo:
Precision 6262sp
Precision 46mm wastegate
Tial 50mm bov
Hahn intake mani
Zzp turbo mani
Hahn intercooler piping
Precision couplers and t-bolt clamps
Cxr intercooler (huge) 12x4x30
body/appearance:
cobalt ss/sc front bumper and lip
tinted tails
debagded
painted bowtie,3rd brake light,and side markers
zzp triple gauge pod
autometer boost and oil pressure
aem wideband
fiberglass racing buckets with nrg 5pt harnesses
ark shorty antenna
There is more, I will update later as I'm @ work lol enjoy
Old Aug 16, 2010 | 09:49 AM
Supercharged Guy's Avatar
That is a **** ton of mods lol
It seems like it's gonna be a sweet build
Good luck with it
Old Aug 16, 2010 | 10:03 AM
iboost's Avatar
is that it?
Old Aug 16, 2010 | 10:14 AM
kxrida2000's Avatar
o my shes finally coming together
Old Aug 16, 2010 | 10:16 AM
rico's Avatar
about time
Old Aug 16, 2010 | 10:32 AM
bykryder83's Avatar
I forgot to put a lot on that list but I'm @ work and my droid is a piece of garbage, soo ill wait till later to finish the list and try to post pics....only prob right now is she will not start!! Says reduced engine power and engine disabled
Old Aug 16, 2010 | 10:36 AM
rico's Avatar
i still got the pics u sent me i think lol
Old Aug 16, 2010 | 10:37 AM
bykryder83's Avatar
Thanks guys, its been a long ass time in the works..I've had kids since I started the build and changed my mind a million times ect. Lol.........rico thought ud like this
Kxrider thanx man, how's ur car c@oming along? Did I point ya in the right direction??
Last edited by bykryder83; Aug 16, 2010 at 10:37 AM. Reason: Automerged Doublepost
Old Aug 16, 2010 | 10:38 AM
rico's Avatar
haha yes i wanted u to post it up
Old Aug 16, 2010 | 10:39 AM
bykryder83's Avatar
Rico! Post them up if ya can/would?? Id appreciate it man
Old Aug 16, 2010 | 10:45 AM
rico's Avatar
Old Aug 16, 2010 | 10:47 AM
bykryder83's Avatar
Niceee!!!!!! Ill post more later
Old Aug 16, 2010 | 11:11 AM
kxrida2000's Avatar
it is better i think something is going on with my throttle body cause im throwing tps codes but when i rev the car when it comes down it dies so im still trying to figure out the issue and a new bov fixed the flutter issue
Old Aug 16, 2010 | 09:27 PM
StevesBlack06's Avatar
man all this and you didnt even say thanks for lettin you use my garage... haha. jk man. ill take some pics with my galaxy S and post them up.
Old Aug 30, 2010 | 12:09 PM
bykryder83's Avatar
Update: I fired it up this Saturday, just to see if she would run....yuppp!!!! Sounded like a freaking beast!
Now I need a good tune,downpipe and side exit exhaust and ill be ready to drive her after 2 long ass years of waiting,changing my mind,short on cash ect.! I'm planning on breaking into the 10's with this car so wish me luck..
Old Aug 30, 2010 | 12:22 PM
rico's Avatar
hurry da eff up
Old Aug 30, 2010 | 01:59 PM
bykryder83's Avatar
I'm tryin in tryin lol, shortage on funds again...
Old Aug 30, 2010 | 02:18 PM
rico's Avatar
true my car might be randomly selling
Old Sep 23, 2010 | 07:44 AM
bykryder83's Avatar
Zzp 3 inch turbo downpipe (custom)
Zzp wastegate dump tube
Magnaflow 3inch race muff
3inch side exit exhaust
Trifecta tuned
CAR IS RUNNING!!!!!!!
Old Sep 23, 2010 | 01:21 PM
BlackCobalt707's Avatar
vids and pics!!!
Old Sep 23, 2010 | 08:46 PM
bykryder83's Avatar
Working on it lol. Tryin to wrk some probs out
Old Sep 24, 2010 | 09:13 AM
i know how that goes lol
Old Sep 26, 2010 | 03:59 PM
Brags's Avatar
NIce work! I just found this thread, 2.2 love.
Old Oct 11, 2010 | 01:05 AM
conerboner's Avatar
Update?
Old Nov 13, 2010 | 05:28 PM
bykryder83's Avatar
Got more pics and vids....took some pulls last night@ 15 psi. Tires just spin all the way to 120! Clutch is slipping and im not even at 35 psi yet lol! Hopefully steve will post up the vids
