Which color wire from the header o2 sensor reads lambda?
Old Sep 2, 2008 | 11:30 AM
rrutter81's Avatar
Just curious since im going to be cutting that wire and using my LC1's narrowband in place of it.
Old Sep 2, 2008 | 11:32 AM
ei3dag3's Avatar
isn't it the purple one with a white stripe?
somebody correct me if im wrong.
Old Sep 2, 2008 | 03:09 PM
rrutter81's Avatar
Also if anyone has done this, let me know. Either way ill be the guinea pig and do it in the chevy parking lot if something goes wrong and just buy another o2 sensor.
20+ views but no confirmation?
meh... bumpity
mkulrey13's Avatar
i assume the wire thats not red or black.. but thats my guess
Old Sep 2, 2008 | 07:08 PM
rrutter81's Avatar
lol i havent even opened it yet. Generally i get a lil excited and start snipping if i look so best to ask now before i uncover it.
btw nice answer smart ass. :P
im assuming if the wire isnt white, red, or black im good.
ok update....
i see 2 whites which im assuming are heater wires, a black and a grey.
the grey i would assume is the sender but bosch generally resorts to black for senders..... ideas?
how helpful... jeez, cutting black then
Old Sep 2, 2008 | 07:29 PM
jeremie's Avatar
ill tell you in a second
hold on before you **** something up
Old Sep 2, 2008 | 07:36 PM
rrutter81's Avatar
nah i already cut it since i was 99.9999% sure.
btw it works!!!!!!!!!!!!
Cut the BLACK wire from the o2 sensor and use the yellow wire from the LC1 in it's place.
MUAHAHAHAHAHAHA 14.7 AFR nonstop. GOD I HATE NARROWBAND. Finally the end of fighting with this narrowband crap that has been screwing up my tune!!!!!!!!!
now to see if my wideband is off by waiting for it to explode.
but seriously..... my o2 sensor was going so whack i was getting pissed.
jeremie's Avatar
which wire did you cut
Old Sep 2, 2008 | 07:56 PM
rrutter81's Avatar
black one
i know it is right since im reading 14.7 at idle instead of 12.5.
Next time im skipping the 2nd o2 bung and just using WB all the way.
update:
Beat on my car til it read 170 IAT2s....
no knock, no issues.... happy camper
Old Sep 2, 2008 | 07:59 PM
mkulrey13's Avatar
you didnt cut it did you? I hope you left it and jsut shaved some of the rubber off of it and spliced into it..
Old Sep 2, 2008 | 08:55 PM
rrutter81's Avatar
cut entirely... i dont want 2 o2 sensors sending a signal to the pcm. I left the heater wires and the sender ground intact just incase i was wrong.
The object was to use my WB as the narrowband sender.... not the narrowband fighting with my WB.
Ive seen it brought up a zillion times in the forums but i didnt see anyone else do this.
Old Sep 3, 2008 | 10:12 AM
rrutter81's Avatar
Update:
well took it in on my hour 1/2 ride to work and got 42 mpg. Im sure it was the narrowband going out.
Old Sep 10, 2008 | 03:43 PM
NGKTECH's Avatar
Original sensor is NTK not Bosch
NTK sensor colors are as follows
Black-signal wire
Grey- ground
whites-heater + and - (polarity does not matter)
DarrenGC
Dec 24, 2021 01:55 PM
Sep 27, 2015 08:53 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
