F35 - Project 6k sidestep
Old 03-25-2016, 01:06 PM
06blackg85ss's Avatar
not bad man, been waiting years for someone to finally do something with these.
now if it will help from stripping 3rd gear, I'd be all for it.
haven't had a trans break on a launch yet, but 3rd gear rolls have been killers (have 3 broken f35's in my garage all did the same thing)
Old 03-25-2016, 04:06 PM
LNFwagonSS's Avatar
Thanks. I am hoping the case flex is at least partially to blame for 3rd and 4th gear failures. Only one way to find out. Still, those gears are weak because of the overall size of the grears combined with the tooth profile. However, WPC(micro shot peening) and cryo treatment of those gears should help. Combining those treatments with this brace, gives me high hopes 3rd and 4th gears failures will happen at a much higher tq value.
Update: appointment has been set for monday to have brace and bellhousing scanned for dimensions using a probe type cmm.
Old 03-25-2016, 05:31 PM
LNFwagonSS's Avatar
Furthermore, not only does this potion of the case flex, it also stretches permanently where the output bearing is pressed in. The more the case stretches causes more deflection between input and output gears. Because of this, I am also looking into output bearing sleeving options as this brace will not help deflection if case is already stretched beyond what I deem acceptable. But it will still prevent the case from breaking even if case is already stretched too far
Old 03-26-2016, 10:41 AM
06_ion2's Avatar
I assume that's what happend to my f23 3rd gear. It shifts into the slot but just fin grinds like hell and won't catch.
Old 03-26-2016, 11:23 AM
Probably the syncro
Old 03-26-2016, 02:06 PM
LNFwagonSS's Avatar
Anybody interested in testing this out? I need a car that makes between 450-500wtq(must provide dyno sheet for my info so I can see your tq curve). I would only charge for rebuild costs, 3rd&4th gear cryo and WPC treatments( probably around 350$ extra for these treatments of 3rd & 4th). Free brace for being my guneia pig. Lower mileage trans preferred.
Old 03-26-2016, 05:34 PM
Axelthered05's Avatar
click
Old 03-26-2016, 06:40 PM
KMO43's Avatar
I believe my car qualifys
Old 03-26-2016, 06:47 PM
LNFwagonSS's Avatar
Then let me fondle your gearbox. She will be primed and ready for you to do her dirty when I'm done with it
Old 03-26-2016, 06:53 PM
Kmo will need it for sure
Old 03-26-2016, 08:01 PM
  #36
KMO43's Avatar
I have 2
Old 03-26-2016, 11:55 PM
  #37
LNFwagonSS's Avatar
All that work, TWICE, and it's still ugly. Although dimension are ideal, which is all that matters. This is still not exactly what it will look like. There won't be any sharp corners and the OD will flow smoothly on the milled aluminum braces. Depending on how quickly I can get 2 made(one for me and one for higher tq testing) I may just a wait few extra days for final aluminum product to put in my trans.
Old 03-27-2016, 12:16 AM
  #38
KMO43's Avatar
Do I need to provide a dyno for u? ��
Old 03-27-2016, 12:23 AM
  #39
LNFwagonSS's Avatar
For testing, yes I would like to see a basic tq vs hp curve dyno graph.
Old 03-27-2016, 12:34 AM
  #40
KMO43's Avatar
My tq failed last dyno
Old 03-27-2016, 12:41 AM
  #41
LNFwagonSS's Avatar
I thought you were getting on the rollers here in a couple days?
Old 03-27-2016, 12:44 AM
  #42
KMO43's Avatar
Yes the same one i did last time where TQ didnt work. But I'm looking for 500s
Old 03-27-2016, 01:14 AM
  #43
LNFwagonSS's Avatar
Ugh! Your Killin me smalls. Cant make any claims without some proof KMO.
Old 03-27-2016, 01:23 AM
  #44
KMO43's Avatar
I have proof of the 481 and will have new numbers tomorrow or Monday. I hope TQ works too I talked to Eric about it already
Old 03-27-2016, 06:04 AM
  #45
mongorat427's Avatar
Make it out of 1 piece of steel or titanium
Old 03-27-2016, 12:48 PM
  #46
LNFwagonSS's Avatar
I have had some second thoughts on using 6061 because of the amount of torque it has to hold down from tightening 5th gear nut, not to mention the the output shaft wants to move upward towards 5th gear with forward torque due to the gears helical cut. Thanks for the suggestion. What are your thoughts on using 7075 alum?
Old 03-28-2016, 04:20 PM
  #47
LNFwagonSS's Avatar
Gonna go with stainless steel.
Old 03-28-2016, 04:29 PM
  #48
South Central *********
JapEatr's Avatar
I hav 3,190 mile F35 with LSD. No dyno graph yet but 550 is likely for a 4th gear pull.
Old 03-28-2016, 06:45 PM
  #49
LNFwagonSS's Avatar
382 or 405?
Old 03-29-2016, 03:33 PM
  #50
LNFwagonSS's Avatar
Still playing with final dimensions. Just wanted to share these images. Pretty sweet.
Quick Reply: F35 - Project 6k sidestep
